Question about Kenmore 659 Electric Dryer
How do I remove fron panel
I have removed the lower front piece of the dryer, How do I remove the main front panel consisting of the door? Thanks
  • onthethejob1
    onthethejob1 May 11, 2010
    please send model number
  • Anonymous Mar 30, 2014
    how do i remove lower front panel below door on kenmore 800 electric dryer
  • 979 Answers
Try taking off the top of the dryer. This will give you easier access to the front portion of the dryer. I know it is the long way around, but it is the easiest.
Posted on Jan 14, 2009
How to take off control panel on kenmore 970-c85092-00 dryer. dryer runs but no heat
Hello there and thank you for choosing fixya
Here is the full repair breakdown for you
Whirlpool and Kenmore style dryers - how to take apart: disconnect power first - Many dryers that I see have the two piece front, but some are the full front with no lower access panel on the bottom front ( see paragraph below ). The lower panel can be removed by using a straight screw driver to pry it off the upper clips, place screw driver in the middle top area ( below the door opening ) and "pop" it out towards you, sometimes you may have to do this at the side top corners of the lower panel as well. Once un-cliped from the top clips, the panel will have to be lifted up off the lower clips towards you. Once the lower panel is off, you should be able to see 2 screws on the bottom corners of the door panel, loosen these 2 screws off a couple of turns but do not remove them. From here you can see the idler pulley, motor, belt break switch and part of the belt. To go further in the disassembly, lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver here to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side, remove the metal clips to allow a more loose wire harness, hold the drum up slightly in one hand and tilt the top of the front panel towards you, you can now lift it off of the screws that you loosened earlier and place it on the right side of the dryer cabinet. On the dryers with a full front, use the same directions but you can ignore the lower panel and the loosen the screws parts. The front will lift off of 2 clips about 6 inches from the bottom and again be placed on the right side of the cabinet. You should undo the belt from the idler pulley and motor pulley, now you are ready to remove the drum. Just grab hold of both ends and lift it out. This style of dryer also has a rear access panel, you can see the operating thermostats, heat element connections from this point.
May 17, 2011 | Dryers
HOW DOES THE FRONT PANEL REMOVE -FOR CLEANING THE BURNER AND MOTOR
For the model dryer you have listed, the dryer cabinet can be removed for cleaning by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior.
Once you have completed your inspection and cleaning of the dryer interior re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you have any questions about this repair, or if the model number is different, please post back and let me know. I hope this helps you.
Apr 18, 2011 | Roper RGS7646KQ Gas Dryer
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
How do I get the front panel off of the LG dryer? I have unscrewed the actual door and screws around the drawer, I am trying to vaccum out the lent under behind the front panel piece.
remove the top panel screws on the back of the unit first,then the control panel in front,then the lower panel along with the front cover with the door
Nov 18, 2010 | LG DLE5955 Dryer
MAYTAG DRYER MDE3757AYW MAKING CLANGING NOISE CONSTANTLY WHILE DRYING ANYTHING FROM TOWELS TO SHEETS, ETC. SOUNDS LIKE PIECES OF METAL LOOSE. NOTHING ABNORMAL IS IN THE DRYER SUCH AS BUTTONS, ETC....
Sounds like the drum roller supports are warn out. Unplug the dryer. Remove the two screws on the lower front panel and tilt the bottom of the front panel out and remove the front panel. Mark and remove the wires going to the door switch. Set the front panel aside. Remove the four screws holding the drum shroud and lift up and out. Set to one side leaving the wires attached. Go to the rear of the dryer and remove the small access panel, Remember how the drum belt is attached to the tension spring loaded pulley and motor pulley. Remove the belt from this assembly and go to the front of the dryer and remove the drum. The drum rollers are located on the rear bulk head of the dryer. Check to make sure that they spin ok or if they are warn out. Replace both rollers. Check the glides on the front shroud. These are teflon glides that the main drum ride on. IF warn, replace glides. Reassemble the dryer in the opposite way in which it was disassembled.
I hope this is of some help.
Jan 25, 2010 | Maytag Dryers
What's the easiest way to open up a dlb6850 dryer to check the belt?
Unplug the dryer.
The easiest way to check the belt is remove the plate on the lower rear of the dryer. Look in to see if the belt is attached around the pulley wheel.
The only way to change the belt is to remove the screws in the front panel. Open the door. Look up in the door opening and remove these screws. Then you can raise the lid.
If the belt needs changing you must remove the 2 screws in the top right and left sides of the front panel.Just inside the front panel.Then disconnect the door switch wires and remove the front panel.
Slip the belt over the drum. Then open the lower rear panel to reach in to put the belt around the tension pulley.
Nov 12, 2009 | Hotpoint Dryers
The blue wires appear to go to the FRONT of the dryer. can this be accesed from the front? How do I remove the lower front panel? Thanks, Tim
Hi Tim, I am not sure what kind of problem with the blue wires you are having? I believe the lower front panel is spring loaded and difficult to remove. Most dryers parts and repairs are done through the back, by removing both the large panel and the top small panel to excess the timer and other controls.I have never had to remove front panels unless it was to repair the door switch. Let me know more if you would like.
Shastalaker7
Nov 08, 2009 | Kenmore 659 Electric Dryer
I'm trying to replace the door catch on the front panel of a Whirlpool Dryer model GEW9868KQ1. I've replace the piece on the door but can't figure out how to get the front panel off.
Hi, You shouldn't have to remove the front panel. Just squeeze the latch hard enough to remove it. I hope this helps. Please let me know if I can be of any more assistance.
Thanks
Vic
May 16, 2009 | Dryers
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Can't remove back of Kenmore 66901
believe that model has lower front panel remove it ..clips each side top edge press them down pull panel off ..element ,fuses thermostat behind it
Nov 18, 2008 | Kenmore 62602 Electric Dryer
Kenmore 659 Electric Dryer Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
