Question about Craftsman Garden
How to adjust carbuator on craftsman chainsaw mod 358350810
Engine continues to foul sparkplugs
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: looking for a craftsman chain saw manual model
Please contact Craftsman and get the equivilant Poulan model number. With that you can find an IPL (exploded parts list) here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you want an Operator's Manual you must contact Poulan and request it here:
Poulan.com
http://www.poulanpro.com/node4033.aspx
While there please suggest they make the manuals available on line. HTH & TIA
Lou
Posted on Oct 11, 2009
Model 358.355161 craftsman chainsaw. how do ya get to sparkplug?
Well you have to remove the outside plastic case , I know its a stupid design
Oct 22, 2014 | Craftsman Garden
Need craftsman chainsaw manual
2 cycle engines almost all share the same characteristics when setting the carb. this link should get ya going. remember if the piston is damaged you wont pump fuel. carb adjustment screws dont adjust themselves. google(piston blow by) http://www.tillotson.ie/docs/techinfo_HS_US.pdf
Feb 07, 2014 | Craftsman Garden
What is the factory settings on a craftsman 2.3 chainsaw and to adjust carburetor
tighten the two air screws to just tight then slacken them to one and a half turns start the engine and adjust the low screw until tick over then open the throttle to full and adjust the high screw if it cuts out take the high screw to one turn and try that then adjust from there
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a poulan wild thing and I also have a craftsman pull-lite model #358350810 I used them both the other day they worked fine now they wont start spark plug is good gas mix ect
If they both now will not start that is a bit worrying, remove the muffler and check the condition of the piston through the exhaust port, any sign of scuffing or piston damage and tey will need to come apart for further investigation.
Mar 05, 2011 | Garden
HOW TO ADJUST CARB. ON CRAFTSMAN 21 cc BUSHWACKER HEDGE TRIMMER
Does the unit have jet screws marked H and L? Turn (both) CW to stops (lightly), then turn each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Make sure the fuel filter, air cleaner, and muffler are not plugged. Start the engine and allow to warm up, pull the throttle full on and adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when trimming. Allow to idle and adjust the L needle CW for better idle, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but doesn't run the cutter bar. Hope this helps!
Aug 12, 2010 | Garden
Saw will lnot start----needs gas intake adjustment
Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that will allow the engine to start and run. Let the engine warm up, then pull the throttle full on--turn H screw CW until the engine speeds up somewhat. Proper adjustment is when the engine is 4-stroking unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 14, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Looking for a craftsman chain saw manual model 358350810
Poulan.com
Poulan.com
Lou
Oct 11, 2009 | Garden
Cultvator is not starting as we pull start
I take it this is the first cranking this season. The most probable cause is stale fuel. Never ever store fuel in a small engine over the winter. Now, the bad fuel has most probably fouled the sparkplug, so you need both fresh fuel AND a NEW sparkplug.
Your carb is going to be gummed up, but if you'll get the high priced fuel with the "cleaners" (like Chevron with Techron) it may save you the trouble of disassembling the carb.
Mar 21, 2009 | Craftsman Garden
Garden Logo
57 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
