Question about Samsung DLP HL-P5663W 56" TV
Garbled sound with Samsung PN50A450
I have an issue with my samsung PN50A450. The sound is garbledondigital channels not on non standard channels. The garbled sound goesinan out. I tried running the sound through surround sound. Samegarbledsound. I then ran the sound through the t.v. speakers only. Sameissue ofthe garbled sound. I have comcast cable and the cable is rundirectlyto tv. Is it a t.v. issue or a cable issue? Does anyone havethe sameproblem. Anyone have a solution?
  • hunber Jan 19, 2009
    Yes I have the same problem. I also have comcast cable, and frequently get a "resonance" sound making the TV sound horrible. I bought the TV back in November as a Christmas gift for my wife; we just hooked it up about 2 weeks ago. It was purchased from Circuit City, which is now closed, so I don't know what to do. I did a google search, and it seems many others have this problem too. I will try to put a call in to Samsung this week. Also, my does it worse if I have the SRS TruSurround XT turned on; not as bad with it off. Additionally, I notice it even at low volume levels -- like anything above 15.
SOURCE: Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Posted on Dec 29, 2007
Danmart
  • 291 Answers
SOURCE: Popping and fading of sound
The "popping" sound could be electricity jumping from one place to another.An internal SHORT in a transistor, an internal OPEN in a resistor.Intermittent [sometimes it does,sometimes it dose not] arcing electronic parts.
Dust [metal filings,very fine hair that burns like a fuse] & dirt [anything metal], arcing (shorted) capacitors.Bad connections on ANY ground connector.
Possible:: your surround sound MASKED the popping sounds by acting like a FILTER.Which lets me to think that your problem is in the audio section.
Posted on Jun 28, 2008
SOURCE: Surround Sound Not Playing For TV Programs
In the display window, do you see the letters ASC? If so,press the ASC button on the remote to turn it off. You should now have the TV sound thru the rear speakers. Enjoy...
Posted on Jan 28, 2009
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
  • 668 Answers
SOURCE: Can't get clear picture on my 50" Samsung DLP
Most of the Analog viewing will be much poorer compared to HD. Since it it a digital product, it is designed to be used with a digital signal. You will get signal degradation if it has to take the analog and convert it to digital to be viewed and there is really nothing that can be done to compensate for it.
Hope this helps,
Skyassoc
Posted on Jul 04, 2009
I have a Samsung Plasma TV (PN50A450) with sound but no picture.
Y board, Y-buffer board, or panel can cause this problem. Anyways, replace the panel shall be good, because those boards will come with the panel.
Apr 21, 2010 | Samsung PN50A450 50 in. Plasma HDTV
My TV can't turn on and getting clicking sounds...help please!!!
I have a Samsung Plasma PN50A450 and one night the TV turned off and the result of trying to turn it back on was simply the set trying to turn on, making a click sound and nothing happened. I pulled the back off, and attempted the capacitor fix that is well documented on the Samsung LCD TVs. I did have a swelled capacitor that I replaced and also replaced the other capacitors that were the same Microfarad rating, temp and voltage which were replaced in a popular UTube video. That did not solve my problem, so I went onto Ebay and bought an entirely new power board for 69.00 plus 14.99 shipping. Replacing the board took about 3 minutes. TV is now working fine and will go back up on the wall in a day or 2. Note, the power board in my TV was a BN44-00205A. That board is no longer in stock anywhere ( I believe because it has been determined to be a bad board) I replaced it with BN44-00207A. Which I suspect is the board that is being used for replacements of the bad BN44-00205A. It fixed My TV. Hope this helps you. BTW, Both power boards are listed for replacing a board in the PN50A450, but the BN44-00207A Specifically states its for a PN50A450P1D. I took a gamble that the BN4400207A would work. It did.
Mar 01, 2010 | Samsung PN50A450 50 in. Plasma HDTV
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
Bad sound-garbled and goes off on certain channels.
Go into the menu and make sure the SAP is off.
Oct 24, 2008 | Sansui DTV2760 27" TV
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Samsung DLP HL-S5086
Vertical problem and most likely a bad capacitor in the Vetical out circuit or IC.
Nov 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
