Question about Brother Sewing Machines
How is xr1300 on light canvas and denim
Starting out in sewing and would like to purchase xr1300 from costco
I just used it the other day on light canvas and denim is my next thing! Make sure you purchase a heavy duty/denim needle and the right thread and you are all set!!!
It was a breeze and I haven't sewn in YEARS :-)
Posted on Dec 09, 2012
4 Suggested Answers
  • 1116 Answers
SOURCE: where do I put oil in my euro denim sewing machine
I don't think you oil a sewing machine motor.
Clean out the area under the presser foot. Sometimes built-up lint can cause the motor to strain as stitching extra heavy fabric.
If the problem continues, the machine needs to be serviced by a pro.
Posted on Feb 21, 2010
  • 415 Answers
SOURCE: Hello, I have a Shark
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
Posted on May 18, 2011
SOURCE: I need a replacement feed dog and a striker plate for the Euro Pro Deluxe Denim Sewing machine model 1262D
here are 3 sites to email about the parts you need
sewingpartsonline.com
sewvacdoctor.com
a1sewingmachines.com
Posted on Aug 04, 2012
What is "needle maintenance?"
Using correct needle for job and not bending it.
Aug 27, 2017 | Sewing Machines
Is pfaff hobbymatic a heavy duty machine?
The term "heavy duty" sewing machine is thrown about loosely lately. There are new machines (including Pfaff, Singer, etc) for sale advertised as "heavy duty," but I would be hesitant to stitch denim jean hems on them. The Pfaff 807, which appears to be an older mechanical, is probably more "heavy duty" than some newer machines on the market. However, "heavy duty" does not mean that you can sew big canvas sailcloth or heavy upholstery projects. A domestic machine (which the Pfaff 807 is) is really meant for general domestic sewing. If you want to sew "heavy duty" fabric, then look to an industrial machine. Remember that frequent sewing of heavy fabric takes a toll on a domestic machine, ie the motor, needlebar, other working parts, thus hastening the demise of your machine and the more frequent need for service & repair.
Jun 17, 2016 | PfaFF Sewing Machines
I'm looking to buy a neechi 3577, does it see Ieather and heavy canvass
This machine is part of the "household" sewing machine market. As such, it is probably not best to utilize a household quality machine to consistently sew leather, canvas, or thick denim. The motors were not made for constant piercing of heavy fabrics. It might work well for a time, but the machine will most likely incur some damage at some point. If you are looking for something on a long-term basis, you might consider an industrial sewing machine made specifically for that purpose. Some people purchase treadle or hand-crank machines for sewing sail cloth, etc.
Jan 03, 2016 | Sewing Machines
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
I am trying to sew a boat canvas top with sunbrella canvas. my top stitch is beautiful but the bottom stitch is loose and messy. Is this just a tension adjustment and if so what should I be adjusting?
Try adjusting the top tension dial to tighten up the loose stitching on the underside. Generally if you have loose threads underneath, its the top tension and visa versa.
However, if you are using a thread heavier than normal sewing thread through the needle and bobbin (which you probably need for this canvas) then the machine may struggle. I've sewed vinyl seat covers and gave up with my domestic machine and purchased a second hand industrial Singer machine 20U to cope with this heavier weight textile. Generally for anything heavier than upholstery fabric a domestic machine may not be strong enough.
May 04, 2011 | Husqvarna Sewing Machines
Every time I go over a seam, the thread breaks. I just put in a new needle to see if that would fix it. No go. Changed to new thread. Still breaking. Any ideas? shegkel@gmail.com
Sometimes the thread is old and breaks easily, another cause could be what you are sewing requires a heavier needle such as a #14 or #16. If it is denim or canvas there is a gadget called a jean a ma jig, sold at JoAnn fabrics that lets you sew over heavier seams. You didn't give really enough information to really be able to diagnose.
Apr 20, 2011 | Singer 20U73
I have a Mini Ultra machine. Sometimes when I am sewing a heavy weight fabric the needle jams -- that is, it hits the plate instead of going through the opening. What is wrong and what can I do?
Most likely reason is the needle is bending. Try using a thicker needle. Heavyweight fabrics such as denim, duck and canvas. Use a 90/14 or a 100/16 needle if sewing on these fabrics; a lighter 70/10 or 80/12 if sewing on cotton. Singer codes this with a blue top.
J
Please post any question is comment and don't forget to rate my free answer.
Apr 16, 2011 | Kenmore Sewing Machines
How to thread the euro-pro denim machine model 90-1260DX ...or where to locate a manual, Thanks.
I need to know where I can purchase a foot pedal for my Euro-Pro Denim 1260 sewing machine.
Dec 03, 2009 | Euro-Pro 1260DX Mechanical Sewing Machine
Sewing Machines Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
