Question about Watches
Ineed a quartz movement w993 for s. haller - Watches
3 Suggested Answers
  • 3247 Answers
SOURCE: I am trying to find a complete W993 Quartz
Try to download catalog from
http://pmclocks.com/Acrobat/Factory%20Service%20Parts.pdf (6mb) and go to page 86 of the document. Parts for S.Haller w993 quartz are available from this company. http://pmclocks.com/pmpage1.htm
good luck with project.
Posted on Dec 28, 2009
I have a complete Haller W993.
Is this what you are looking for?
d.hind685@btinternet.com
Posted on Apr 04, 2010
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
Changed battery, now buttons on sides do not work, where to get it repaired?
mcdevito75 here, Most likely during the battery change you moved the quartz movement away from the contact buttons. Re-Open your watch carefully and make sure when you press the buttons, each button is pressing against it"s spot on the quartz movement.
Jun 17, 2011 | Mio Motiva Petite Heart Rate Monitor Watch
Watch is not working. Does it have a battery or is it a winding watch?
I examined all the watches on their web site and they are all quartz movements, so it looks like your is a battery operated (I couldn't find 0292 but I did find a 2092 - which has a quartz movement).
Feb 13, 2011 | Giorgio Armani Armani Classic watch...
What is the main internal assembly of the Casio forester watch called? Replacing the battery does not work.
mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
I have an old ladies dress Chopard watch - oval shaped gold with diamonds on the band. I inherited the watch from an estate. I wore the watch from a month and then it just stopped. Should I take it to a...
You need to first know if it is a Quartz watch or an older Wind Up type. I am guessing, since you have been wearing it and do not mention winding it, that itt is probably a Quartz movement in the watch. However, to be clear, If it is older than about 1970 then it is definitely Not Quartz. Then might be what is called an Automatic movement, which is actually a Self Winding Movement mechanism. If newer than 70, could be either Quartz or WindUp. If it is Quartz then the problem is most probably that the watch needs a New Battery. This can be done at a local jewelry shop for around $8 to $15. If it is a Wind Up style then it would need a more complex repair. But sending it to Chopard is still the Last Resort as Chopard could charge you $400 to repair it, I am not kidding, haha. But take heart, most probably you have simply got a Dead Battery and your friendly local watchmaker or jewelry store can fix it for you fast and cheap. Good Luck, W.
Mar 16, 2010 | Watches
How does the swiss eta g10.211 quartz chronograph work
I am not sure if I understand your question. Are you asking how this particular quartz movement operates?
All Quartz movements are pretty much the same operational wise. They can vary greatly in materials used for construction and number of jewels.
At it's basic a quartz watch uses a piece of quartz crystal called a transistor oscillator to vibrate a tuning fork. This vibration is a is brought down by micro processors to a meaningful number then converted into mechanical energy trough the movement and hands.
In the case of a chronograph it means more internal gears and jewels.
Although this is a good movement it is the low side of middle of the road.
The G10.211 is an analog display of hours and measured time. These include hours, minutes and a small jumping second as 6 o'clock. Mechanical date and counters for 1/10 second, 60 seconds and 30 minutes with "ADD" and 'SPLIT" functions. Operated by 2 push buttons.
It has 6 jewels.
If you want to know something more specific please just ask.
Hope this helps.
Dec 31, 2009 | Bulova Watch
Go to any watch or jewelry shop.
Dec 27, 2009 | Watches
Can i replace automatic movement for quartz in a james bond model , and can i do this myself
You can if you have following:
1) Lathe technique skills,
2) Watchmaking skills,
3) Watch engineering knowledge,
4) All necessery watchmaking hand tools,
4) Watchmakers lathe,
6) Microdrill,
7) Omega or ETA manufactured quartz movement
8) Original Omega dial for this particular movement,
9) Watch hands for this particular dial.
At the very end your watch will have no market value at all exept sentimental value for yourself.
Rate me, please.
Aug 22, 2009 | Omega Seamaster 2253.80 Wrist Watch
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 | Watches
Differentiating omega model 2561.80 and a model 2531.80
Kris,
The only way to find out what model of Omega you actually own is to open it.  This should have been done by whoever you already brought it to.  Omega only prints their model #'s on the movement inside the watch.  If you open the watch, look on the movement, you'll know what model you own.
Jan 18, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Watches Logo
273 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
