Question about Tamron 28-200mm f/3.8-5.6 LD Aspherical IF Super II Macro Autofocus Lens for Minolta
AF not working
On my Sigma Aspherical IF 28-200 mm lens the autofocus will not work! When i connect it to my camera it makes this grinding/clicking noise like its trying to work but about 15 sec into it the camera switches to manual. I can focus it manually but it gets stuck! and i do not want to force it and harm the lens any more! when i take the lens of the focus moves fine but i noticed that the little screw looking thing that connects to the camera witch is how it focuses will only turn when i focus in word and will jump occasionally when focusing out!
  • 19,396 Answers
Try cleaning the sensors in front of the camera.
If you still get the problem it is an internal fault, probably the autofocus optic sensors are not working.
The motor used by autofocus is same as manual focus, therefore the problem is on sensors, wirings or logic board.
The repair involves taking apart the camera completely and testing components and parts.
Posted on Jan 10, 2009
    Sergeant:
    Novelist:
  • 326 Answers
I would start to diagnosis the problem as follows: When the lens functions properly and is on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the smallest f-stop (largest number such as f22), sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. Also, the electrical connection between the camera body and the lens is via the five little ball like metal contacts (4 together and one wider spaced) found on the black ring on which the aperture ring is located. If either these contacts or the contacts on the camera body are dirty, the automatic functions may fail. DO NOT use any liquid cleaner. Gently rub the contacts with a rubber pencil eraser, being very careful to hold the camera body or lens in a position that will allow any debris to fall downward away from the body or lens. Do not overdo it. If this does not get you on the right track, let me know what you find and we will proceed from there.
    Sergeant:
  • 378 Answers
Open the lens unit completely and clean it properly.its stuck up completely.clean it to solve this problem.
Sigma 28-300mm f/3.5-6.3 DL Aspherical IF Hyperzoom Autofocus Lens for canon slr compatible with Canon t3i dslr
Sigma produces lenses for different brands of camera's. The optics are the same, but the connection differs from brand to brand. So if you have a Sigma lens for Nikon, you won't be able to use it on a Canon or Sony. Unless you buy a adapter. But when you start using an adapter, you will lose the Af in most cases, because the electronic in the lenses differ also. and that can't be bridged.
Dec 14, 2013 | Sigma 28-300mm f/3.5-6.3 DL Aspherical IF...
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 UC Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts but still get...
From working with third party lenses in the past what I've found is that Canon doesn't give up the "chip" technology so the older lens can not talk to the newer cameras. I suspect that Canon does this to promote their lenses over the competition. You might be able to send the lens to Sigma and have them re-chip it and have a great lens again.
Dec 26, 2010 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
I have the sigma 70-300mmD i just bought for my nikon D40 and i am having trouble with the auto focus. it will not autofocus can anyone tell me what i am doing wrong and or where i can download the...
The Nikon D40 does not have an autofocus motor, relying on the lens having one. This Sigma lens does not have such a motor, relying on the camera having one. Nikon designates lenses with an autofocus motor AF-S, Sigma calls theirs HSM.
Dec 17, 2010 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Can I buy an adapter to use the 28-200 mm Sigma Aspherical lens fitted to my Pentax MZ-50 film camera on my Canon EOS 1000d DSLR. Would it work?
You may be able to find an adaptor, but I doubt it and you would lose many functions in any case. It could end up that the lens will not auto focus or that it would not meter properly. These adaptors are made so that specialty lenses (such as fisheye or shift lenses) can be mounted on cameras when needed. Your 28-200 would probably be cheaper to by in an EOS mount.
Nov 17, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 DL Hyperzoom macro Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts...
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
May 19, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
Feb 23, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Tamron 28-200mm f/3.8-5.6 LD Aspherical IF Super II Macro Autofocus Lens for Minolta Logo
160 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
