Question about Fujitsu Heating & Cooling
Fujitsu ast24rgb remote won't turn on air conditioner
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
  • 400 Answers
SOURCE: Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Posted on Nov 04, 2009
  • 12 Answers
SOURCE: REMOTE WONT TURN ON AIR CONDITIONER TRIED ALL THE
If the remotes work on other like units but not on that one, it probably has a bad control board.
Posted on Jan 17, 2010
Where can I find a new remote AR-DL10
Hi gdpotter,
Here's the LINK for the original remote control.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 29, 2011 | Fujitsu 24C1 Air Conditioner
Hi I have a problem with my Fujitsu wall mounted air conditioner ,model AST24RGB-W the outdoor unit fan is running but there is no cold air coming out from the inside unit I put it on high cool to get cold...
I think, your compressor is not working. Check with amphs meter. If less amphs gas leak. Arrest the leak and re charge gas. If tripping with high amphs change capacitor. Still high amps, compressor is defective.
Dec 26, 2010 | Fujitsu Heating & Cooling
Hi I am searching for Fujitsu AST24RGB Circuit board as the ants and gekkos damaged the original. Are they available and if so how do I go about getting one? The rest of the unit is fine.
Google Fujitsu web site and follow prompts and have your model number of your unit handy. I have ordered several parts for Fujitsus on line No problem Rus.
Nov 22, 2009 | Fujitsu 24R1 Air Conditioner
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Jan 23, 2009 | Fujitsu 24C1 Air Conditioner
No heat or cold?
is the inside unit in a closet or the attic. if in the attic there may be a float switch in the drain pan and you might have hit it causing the outside unit not to come on
Jan 04, 2009 | Fujitsu 24R1 Air Conditioner
Clicking noise
There is no solution. I have the same problem. The issue is that the system clicks as the thermostat regularly checks the temperature. It is a major design problem and I hate it too/
Jul 22, 2008 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
