Question about Sharp EL-1801P Calculator
MY SHARP EL-1801P PRINTS SYMBOLS INSTEAD OF NUMBERS
PRINTING
SOURCE: Sharp EL-1801V 12 Digit 2 Color Printer
SHARP EL-1801V DON'T KNOW HOW TO SET THE DATE AND TIME
Posted on Jun 12, 2008
SOURCE: time date
i know i set this model before but i recently tried to again and it didn't work right for the time for some reason... but i do remember that you flip the middle switch to rate set, the you put in the date 12.10.08 seperated with a "." then you hit the time date button once. then you do the same with the time, hours(militarytime).minutes.seconds all seperated by a period I.E if it were 1:30 PM you woud put 13.30.00, then you hit the time button again.. the date and time should be set, might have to do it in the opposite order... but i know that is generally how its set
Posted on Dec 11, 2008
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SOURCE: How do you fix or set a time and date for Sharp
how do you fix or set time and date for sharp EL-1801p electric calculator
Posted on Apr 25, 2010
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out.
or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out.
probably it willcome with anything that is stuck beneath the printer
M.P
Sep 11, 2014 | Sharp EL-1801P Calculator
After changing the ink roller, the machine is printing nonsensical characters.
You have a IR 40T replacement cartridge instead of a 40T
These are sold under the NR42-2 number as replacements for the Sharp 1801P but they do not fit. IF you look closely at the Sharp Models it lists on the package, it will say Sharp EL-1801V. I have not found a working replacement yet.
Dec 02, 2009 | Sharp EL-1801P Calculator
I want to set the correct date and time and also the tax percentage on my sharp el-1801p calculator
go to the commanding prompt and type cd.. there you will type date and time there you can set the date and time
Sep 19, 2009 | Sharp EL-1801P Calculator
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
I have a Sharp EL-1801P III. I want to make it so that when I type numbers in and his add it automatically puts the decimal in for me. For example if I typed in 3596 it would make it 35.96. Is this...
Your calculator has a decimal counter (top center of calculator starting with the letter F654321A) for lack of a better name for it. Anyway mine is set at A. It puts the decimal in for me. I hope this helps you. if you haven't figured it out by now.
Jan 15, 2009 | Sharp EL-1801P Calculator
Errors??
Sounds like the printwheels are out of time. Sorta of major repairs. gears on side of printer have to be lined up in proper areas. there are small black arrows on the gears. Best bet is look at a working machine and try to line up. Machine may not be worth the time unless you jsut want to try it. Sharp uses the same printers in many different models.
Jun 21, 2008 | Sharp EL-1611P Calculator
Sharp EL-1801P Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
