Question about HP DeskJet 9650 InkJet Printer
Laptop suddenly stopped printing to printer wirelessly
I tried restoring my computer to early point, also tried reinstalling printer disk, changed things in "setting properties" and don't remember what it said before changing settings.
  • tina722 Jan 11, 2009
    I need my expert to contact. I tried reinstalling and it stops at "search from a list of detected printers" because my printer is not listed.
    Problem was solved. Awesome expert.
    Sergeant:
  • 378 Answers
If the driver reinstallation did not help that means its the communication problem with the device.just go to device manager, and uninstall all the usb mentioned there.scan for hardware changes.it will reload all usb devices by detecting them 1 by 1.this will solve the communication problem.thanks.
Posted on Jan 10, 2009
  • HP Master
  • 19,396 Answers
Try first doing system restore to a date before you had the printer problem.
If that does not work reinstall drivers, this time starting installation with printer unplugged, and setting printer as default on installation.
If you use Vista also do the following
Sometimes on Vista you have to run setup software, like the printer driver setup wizard as Administrator.
To do that you click the right button of the mouse on the installer file and chose 'Run as Administrator'.
Remember to start the file setup with Printer USB Unplugged, or Vista may install the wrong driver by itself. The software setup wizard will tell you when to plug in the printer.
Chose printer as default during setup.
If you have already fixed keep this for future reference.
Here is How to run as administrator on Vista:
Windows Vista Run As Administrator
  • HP Master
  • 13,433 Answers
HAve a look into the printers and faxes what the status of the printer? is it online? try printing a test page.
if you are unable to print a test page, delete the printer, uninstall the software, unplug the printer, reinstall the software and plugin the printer when asked.
after the printer is reinstalled you may need to restart and it should work.
  • Ekse Jan 11, 2009
    Issue with printer not printing and printer sharing for 2nd computer fixed over remote support.
Have Samsung 3170 printer connected to wireless access point (WAG325N). It has worked fine as a network printer for 8 months and now will not print.It has an xp and vista mc's on network and both have...
1. check the name of the printer after clicking "print and check if you have the printer listed as the wireless printer as opposed to the USB.
Apr 19, 2010 | Computers & Internet
Printer not picking up wireless signal to print from laptop.
so the printer was working before.
Did you try to change any settings on the router?
Is there any other wireless computer or other device able to go online ?
You will need to check the wireless settings of the router.
Click Here for step by step solution
Oct 30, 2009 | D-Link Computers & Internet
Canon printer not functioning
Sir,
Restart your PC and Printer once and even it does not work then
your need to reinstall driver for that printer.
please post back if anything changes.
thank you,
Jan 10, 2009 | Office Equipment & Supplies
Wireless Connection failed
Did you make any hardware or software changes? You don't say.
Try seeing if your wireless radio is turned on. Most laptops have some kind of switch or Fn key combination that will turn off the wireless networking radio to save power. You might have inadvertently shut it off.
On the other hand, if it's a software thing and it only happened today, try using System Restore in Accessories --> System Tools and go back a day or two. If it's a software issue, that may resolve it.
Post back with any problems.
Dec 29, 2008 | Computers & Internet
HP C7280 - Just Stopped printing on only One of my computers
Had a similar problem. Try downloading the printer drivers again from HP website.
Dec 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
Network printing suddenly stopped working
Perhaps you might wanna try checking the IP address of the printer and see if it matches that of the ones that are mapped in each individual computer. There might be many factors in the "strange" events that have occured (PC gremlins, i call it). That should be an initial starting point.
Resetting the router wouldnt help, cause it is the router that issues different dynamic IP addresses (otherwise known as DHPC) to each and eveny node connected to the netwrok as well.
Another important thing to note is HOW these devices are connected to the router. Wirelessly? Wired connection? The fact that you can see the printer via the router means that there is no problem with the router's end, so the problem lies in the intermidiate connection from the computers to the router. Try to work on this angle. Thanks.
-Technomancer
Jun 02, 2008 | ASUS WL-500g Wireless Router (WL500GDLX)
Fine one day, gone the next!
check for viruses first, then try by reinstalling the drivers, if not solved go to device manager and check for usb printing support in usb , if you can see just uninstall it and reinstall the drivers for the printer, if still you have the same problem then try with another usb,
post back your findings
May 30, 2008 | HP DeskJet 5550 InkJet Printer
Samsung Printing Trouble
make sure that when you go to print under propertys choose color tab and then color
Apr 07, 2008 | Samsung CLP 300 Laser Printer
Won't print
try to Download from this link:http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:582:0:0
for the operating system ur using ....
Mar 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Open Questions:
See all HP DeskJet 9650 InkJet Printer Questions
HP DeskJet 9650 InkJet Printer Logo
42 people viewed this question
Ben Johnson
