Question about Canon DR Office Equipment & Supplies
Paper tray not lifting on canon dr-9080c - DR Canon Office Equipment & Supplies
mohanchennai
  • 490 Answers
SOURCE: Canon DR-9080C paper tray lift broken
Michael, U can buy 9080C service manual at tradebit.com 9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
Posted on Feb 02, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Posted on Jul 10, 2009
mohanchennai
  • 490 Answers
SOURCE: Paper tray at front of scanner will not lift.
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
Posted on Jul 28, 2010
SOURCE: canon DR-3080c scanner, tray wont lift and says
A scanner will jam for any number of reasons: It's dirty, the wrong paper type is being used, or the rollers on the scanner that feed the paper through its pathway are worn down. While cleaning the printer periodically and using the correct paper type are easy fixes, but thuis are not the the problem, it means the roller is worn out and will need to be replaced.
Take care.
Posted on Sep 17, 2010
mohanchennai
  • 490 Answers
SOURCE: dr-9080c tray lifts up and down
IT could be a problem with the paper sensor. Please clean the sensor in the paper tray, it looks like a 'black dot' .
Posted on Nov 11, 2011
CANON DR-9080C TRAY MOTOR BUZZES THEN I GET AN ERROR THAT SAYS NO PAPER FOUND.CLEANDED THE SENSOR WINDOW, CHECKED ALL THE CONNECTIONS BUT STILL NOT FIXED.
Hi Marc,
***Make sure that you plugged the cable that comes from the camera detect PCB (sensor) into the document board assy (metal part under the plastic tray).*** You said you checked all the connections, but I would recheck them, and trace them all the way through the metal lift mechanism...the cabling has junctions that run through the metal box all the way across to the right side of the machine and plug into the 10Sub PCB. You will have to remove the metal lift mechanism and unplug to cables from the 10Sub PCB. You will also have to separate the upper and lower parts of the metal box. You might as well clean the metal box out, check the plastic gears, make sure the motor is plugged in, and regrease the plastic gears if they look like they need it. Check the wiring for crimps or breaks too. When you reassemble the box, make sure that the black "U" shaped photo interrupter doesn't get knocked out of place. If everything still looks ok, I would replace the sensor and retest. The buzzing noise from the lift tray may or may not be related. There is a stepping motor in the lift tray assy that could have a problem. Order them both, they are pretty cheap.
Hope that helps...let me know
Feb 13, 2015 | Canon DR-9080C Path-Through Scanner
Paper will not feed. the lift tray does work. 1.5 to 2 inches of the top of the paper feeds before it stops. when i used count only still get the same problem with
A01 is pickup error. Clean the paper sensor in the paper lifting tray and try. Clean the rubber rollers also.
Nov 17, 2011 | Canon DR-9080C Path-Through Scanner
Dr-9080c tray lifts up and down
Nov 07, 2011 | Canon DR-9080C Path-Through Scanner
Canon scanner-the document lifting table is not lifting, it makes a noise trys lifting then stops, then a "no page was found in feeder" message appears on my computer.
At the bottom of the tray there is a sensor for checking "Home Position". When you power on the system initialises and the tray goes to the home position. Please check this sensor if it is dislocated or a piece of paper is blocking this optical sensor. Normally these sensors don't fail. Also clean the 'black dot' just under the rollers. There is a paper sensor under this and dust can prevent sensing the same. Even after this if you have noise, there could be hardware problem.
Sep 24, 2011 | Canon DR-9080C Path-Through Scanner
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
Feeder tray not lifting
The paper tray is lifted by set of levers under the tray and the levers are operated by a motor, under the display panel. Check if the levers are in position. The motor movement is transferred to the lever by a plastic gear. Check if it is deformed. Normally motor does not fail.
S. Mohan, India
Aug 06, 2009 | Canon DR-9080C Path-Through Scanner
My Canon Dr-9080C isnt pulling the paper into the scanner. The input try elevates, and then returns to it's original position, without the paper being pulled into the scanner, as if there wasn't any paper...
The scanner is assuming there is no paper. Just under the rubber rollers, in the paper tray there is a paper sensor. Clean that area with a damp cloth. Keep some papers and try "count-only". It it works then sensor is okay, else, you need to check the sensor.
S. Mohan, India
Jul 12, 2009 | Canon DR-9080C Path-Through Scanner
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
S. Mohan
Jan 30, 2009 | Canon DR-9080C Path-Through Scanner
171 people viewed this question
old marine
old marine
