Question about Husqvarna Viking 1
Thread cutter on viking ruby not cutting bobbin thread
SOURCE: Husqvarna Viking #1plus bobbin problem
I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line
Posted on Dec 16, 2008
SOURCE: I have a viking Iris sewing and embroidery machine
When I had that happen, it turned out that I had not wound the bobbin thread correctly (it was not wound tight and smooth enough). Wound a new bobbin from scratch, and all worked fine.
Posted on Jul 10, 2009
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
Aug 19, 2016 | Sewing Machines
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Bobbin thread not cutting
With the bobbin case out of the machine, touch the cutter button. Do you see the cutter arm move from left to right and then back left. If not the cutter arm is out of place. If it does it is something else.
I usually check two things:
1 - your cutter blade might be missing or dull and needs to be replaced. I would not recommend doing this yourself unless you are very good.
2 - many times there is lint or loose threads around the cutter in the area to the left of the needle plate that needs to be cleaned out. You can remove the cover to this area by first removing the needle plate and bobbin case. Then the cover is accessible to pop off by sliding the tip of a small screw driver under the cover at the bottom right corner of the cover. There should be a little opening. Carefully pop the cover off but be careful that the blade mechanism does not come off too. With your finger carefully hold the silver metal blade area steady and pick out the loose threads/lint from around the copper looking metal part. There is velcrow on the tip of the copper metal part so be sure that you don't remove that too. That's what holds the thread for the blade to cut it. If velcrow is missing, or the silver metal part is out of place that could be the problem also.
I recommend that any repairs/service be done by an authorized Viking dealer. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck
May 13, 2014 | Husqvarna Designer I
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Sewing Machines Logo
147 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
