Washer doesn't get clothes clean
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 30, 2012
  • 1 more comment
  • tinkers95815
    tinkers95815 Dec 01, 2012
    Galaxy 110.19101911
  • Richard Roth
    Richard Roth Dec 01, 2012
    Does the agitator move the clothes properly with a full load?
  • tinkers95815
    tinkers95815 Dec 02, 2012
    not really. It move back and forth but, the clothes do not move as they should. I have to reach in and grab the clothes from the bottom and pull them to the top. They will get pulled down correctly but then...? They get stuck and/or wrapped around the agitator. It spins and drains well. It doesn't fill up to the level it used to so I usually add water myself.
5 Suggested Answers
SOURCE: I HAVE FRONT LOAD LG WASHER - CLOTHES ARE SMELLING
We had a similair problem with our LG washer. For some reason, and don't ask me why, the smell only occurs when using liquid Tide detergent. We switched to powdered HE Tide, and the smell went away. I read on another thread that mixing white vinigar with the detergent helps keep the inside stuff bacteria free. I use about a half cup of white vinigar once every month and have not had any mold problems.
Posted on Mar 15, 2010
SOURCE: Washer doesn't agitate properly. clothes wrap around agitator
turn the machine over &inspect the belt.Get the make n model # of it &go to an appliance shop give them the #'s and take machine &prop it against the wall on a tilt &loosen the bolts that hold the pump on REMEMBERING where they go loook at the way the belt is positioned &put&match the new belt where it goes,its like a figure 8 around this place &around that place &carefully take the old belt off &attach it and then but the belt on the pump that u took off &take a bar &tighten the slack up on the pump.Install the boths and there u go try it and let me know. I did it once with a Maytag washer when I was 8 months pregnant and The washer is doing just fine.
Posted on Apr 06, 2012
  • 3 Answers
SOURCE: Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
Posted on May 07, 2012
pokeyd
  • 4 Answers
SOURCE: samsung washer gets clothes dirty
Put a whole house water filter on the cold side of the inlet water. I bet you have well water with lime in it??? Wash your clothes only in cold water. Rub a couple of empty loads with clorox, lime away, oxy clean to remove any build up in your washer
Posted on Oct 21, 2012
I bought a Kenmore Elite washer a little over a month ago. It is a beautiful machine, it is also the worse washer I have ever had. It doesn't get the clothes clean & wrinkles so bad th
Sears sux! How old is that unit? Because if it is quite new then you bought a basic model, and sadly that is what you paid for. Let me know.
Sep 22, 2014 | Washing Machines
Samsung washer gets clothes dirty
Oct 21, 2012 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Top load washer leaving flaky black spots on some clothes. This doesn't happen with every load just randomly, but becoming more common. It doesn't damage clothes if I catch it when they come out, I...
It could be a sign one of the rubber hoses is eroding internally or perhaps a bearing is failing.
If a hose the black spots will be easy to remove, if grease, wiping the spots will spread them and they will be harder to remove.
Oct 08, 2017 | Washing Machines
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
I have a MHWE500VW11 and I hate it! It doesn't get the clothes clean. Give me my old top loader any day. I have to over wash everything on steam clean and it's killing my clothes. I do more dry...
One thing to check is the capacity of the machine. If you used to have a top loader you may be used to packing more clothes in, and the front loader may not be able to clean the same capacity.
Your manual should indicate the maximum weight of clothes for each kind of load. For example a 40 degree mixed load should usually weigh less than a 40 degree cottons load.
If you try washing less in each load you should find your clothes get cleaner.
Jul 25, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a Frigidaire front load washer and used dishwashing soap accidentally. now it wont spin in the final spin leaving the clothes soaking wet
Hello, Welcome to FixYa.
Based on your post I understand you have a problem with a Frigidaire washer that has had the wrong "soap" placed in it.
If you can remove the lower panel on the front you should inspect and insure the shock absorbers are still intact and not broken before proceeding. This is what you'll be looking for...(yours may in fact be plastic cylinder type shocks, that's the older version)
If they are not broken then it should be safe to proceed. Here's what I'd suggest (see below).
Let me know how that works for you and we can move forward from there if this doesn't resolve the problem.
When oversudsing has occurred, have the washer cleaned out by running it without clothing using a hot water wash (with cold water rinse) & ½ gallon of white vinegar. If problem persist after, run a cold water rinse using 1 gallon of white vinegar.
Regards,
Macmarkus :)
May 11, 2011 | Frigidaire Washing Machines
Washing Machines Logo
Top Washing Machines Experts
