Question about Polaroid FDM-0715 Television
No volume on the cable tv setting?
There's volume on radio, cd, etc. but no volume when watching TV on AV channel. At first there was reduced volume, but now now volume??
    Top Expert:
  • Polaroid Master
  • 14,553 Answers
Does the set have a earphone jack? if dirty or damaged it will cut the TV sound out---about the only other possible reason is a audio problem in the TV itself---if possible put ear up to speaker to see if any sound or buzz is heard.
Posted on Dec 04, 2012
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
Dec 24, 2012 | Televison & Video
I can't get the tv to program the cable connection to watch cable
use a scart lead to connect your cable tv box. then on your tv remote press the "source" button or press the "AV" button, you mainly have the options to choose AV1 and AV2 (AV2 is only available if your tv has 2 scart sockets) make sure the box is on and select any AV channel, you should now have cable tv.
Jul 17, 2012 | Disney Princess TV/DVD Combo
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
I have a trutech tv model number plv1615 t I cannot find the manual I want to use it with my video player. Can you help
I'm assuming you have hooked up the video player and tried, and haven't got it to work? If so, Run the video cords to the correct places, i.e. yellow (video) to yellow port (front/back); white and red are sound, insert each to their corresponding places as well. Next, turn the tv on, as well as the video player, (dvd/vhs/etc) - next, if you have a remote use it to access the menu - then scroll through the list (usually with the volume up/down button, channel up/down buttons, or there will be arrow keys to use). Find in the menu the selection to choose which video port to use i.e., video 1, video 2, or AV, which is more commonly used - AV is usually the ports on the front side for tv's like this. If you do not have a remote, to access the menu (if not "menu" button is available on the front of tv) try using the channel up/down buttons on the tv, by pressing them both at the same time - also, using the channel up/down, or volume up/down buttons to scroll through the menu - to select, there will either be a "select" or "enter" button, or as one set of up/down buttons are used for scrolling, the other two up/down are used for selecting. Once you have determined the uses, find the channel selection, and try AV first. You may be able to find it easier first by simply flipping through the channels on the tv until it appears on the screen usually in the upper right hand corner in big letters -- AV. This will be the channel to use for video - if not, there is one other way to make this work - if the tv and video player have a co-axle port (cable cord connection) then use a co-axle cable. Plug it in to the back of the video player, and then the back of the tv. Select Channel three/four ( some video players have a switch on the back, so make sure they are both on the same channel). Most commonly used is channel 3.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 26, 2011 | Daewoo DTQ-19Z4SC 19" TV
Weve got a toshiba tv model 289s4A & want to plug our ps2 into it, cant find how go get the av channel on the tv. We have connected the av cables but when you change channels on the tv, theres no...
If you have the remote, look for the source button. It should allow you to toggle the settings.
Otherwise they are usually after channel 2 as in Hdmi, Av1, AV2 etc..
Good luck
Dec 09, 2010 | Toshiba Televison & Video
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Volume distortion only on tv setting
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Oct 30, 2008 | RCA P52926 52" Rear Projection Television
Polaroid FDM-0715 Television Logo
94 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
