Question about RCA CC-432 Camcorder
Battery on camcorder
I have a rca cc-641 vhs camcorder. under the battery I charge I found a door for another little battery . It looks like a larger watch battery ....what is it for and where can i find a free user guide?
Its for the time and date clock
Posted on Feb 16, 2010
What kind of charger do I need for RCA autoshot 72x camcorder
suggest you contact the manufacturer thru their website customer support
Apr 10, 2015 | RCA Video Cameras
CLASSIC RCA AUTOSHOT VHS CAMCORDER.(DSP3) PROBLEMS
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced.
I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar.
The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder.
The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
Nov 16, 2017 | RCA CC6151 Camcorder
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but...
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
May 15, 2011 | RCA CC-439 Camcorder
The tapedoor to my RCA cc6151 VHS Analog Camcorder won't open.
It is over 18 years old - the probability is that some of the electronic components have deteriorated to such an extent that it is no longer usable.
Aug 22, 2017 | RCA CC6151 Camcorder
Need Manual for RCA VHS Camcorder Model No. CC 285
TRY THIS .GOOGLE Manual for RCA VHS Camcorder Model No. CC 285
MAY NEED A BIT OF SEARHING
IF YOU FIND A PDF VERSION,DOWNLOAD IT,AND BURN TO DISC
KEEP IT SAFE RUN IT ON COMPUTER OR PRINT IT OFF
Feb 15, 2010 | RCA Video Cameras
I'm having difficulty putting a charge on the battery on my panasonic ag 188...the battery hasn't been used in years. Some change is happening when I charge the batt onboard the camera (plugged into the...
I had the same problem. I hope you have a battery charger. The many older batteries I have needed charging, but they wouldn't hold a charge when I tried to charge them with the battery charger. My batteries were the kind that had a memory, and I guess that the battery memories are dead. So, I saw that I had a double ended power cord that came with my camera. I took the battery out of the camera and saw a power-in hole. I just tried connecting the double ended power cord to the camera and to a power hole I found on the battery charger. It worked and gave power to the camera. It did not explode. I could not find a manual on any of the many websites. I think that the camera I bought (Panasonic Palmcorder IQ PV-IQ403) doesn't exist in the available manuals. Maybe you can find a double ended power cord and a battery charger on line or in a store.
The following information might be useful to others. The camera cassette door will not open without having the power on to the camera. The camera connects to a TV with RCA cords.
My camera power switch has 2 settings. Use the camera setting to use the camera to record and see what you are recording displayed on the TV. You must change the power switch to the VCR setting in order to play back the recording and see it on the TV. Change the switch back again to use the camera. (You can also see the playback through the viewfinder.)
My camera has a remote control which is stored in a slot. I found that the battery is in a tiny sliding door. I had to use a screwdriver to gently dislodge it from the case, my fingernail was not strong enough. The movable tab had to be pushed inward to release the catch. The coin battery was not corroded. (CR-2025)
In order to play a VHS-C tape, you must have a VHS PlayPak. The cassette door will not open unless you have a battery loaded into the cassette. When the door opens, you can insert the VHS-C tape into the opening. The VHS PlayPak holder is the same size as a regular VHS tape. It can be found on-line.
May 17, 2009 | Panasonic AG-188 Camcorder
No power is supplied
More to the point, why was your little child using 'shears' unsupervised ?
Mar 08, 2017 | RCA CC4393 VHS Analog Camcorder
Need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
Nov 18, 2008 | RCA CC6254 VHS-C Analog Camcorder
Can't charge the battery
# New batteries need to be drained by using the camcorder until the viewfinder indicates the battery is empty. Follow these steps: Once the battery has been drained, you may use the charger to recharge the battery. # Consult your manual for the amount of time the battery requires on the charger to get a full charge. # A full charge will be delivered by the charger. # Some camcorders have a Refresh feature, which will automatically drain the initial charge on the battery. This allows the battery to fully recharge.
Sep 06, 2005 | RCA CC-432 Camcorder
RCA CC-432 Camcorder Logo
66 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
