Question about SYMA Toys industrial Syma S032 Ready to Fly Gyro
Gyro S111G only hovering not lifting off, help
Gyro s111g will fly , but only at a low hover
5 Suggested Answers
andrec1024
  • 7 Answers
SOURCE: just got the syma s032
So your only getting 20 seconds of flight time when your charging for a full cycle?
I purchased the Syma Chanook and it had the same problem , If you keep running into this problem using the remote control charger than I suggest to aquire a new charger . One that is a plug in the wall . I really dont like to rely on the usb chargers they just dont work as well. If not you still have a 30 day moneyback warranty and I would make them replace the battery or better yet the whole unit if the second charger doesn't work!
Posted on Dec 24, 2010
197jacobs
  • 226 Answers
SOURCE: I have a S107G Gyro
battery need to be replace charge life is over
Posted on Aug 12, 2011
SOURCE: my helicopter (SO32 Gyro) having previously worked
Batteries are available online (amazon and many others) and change easily with only small screwdriver. Overcharging is not the issue. Nearly impossible with PCB (overcharge prevention circuit) hard wired into battery AND in charger. Problem is likely UNDERcharging, overDIScharging, or improper battery care. Battery MUST be allowed to cool 10 minutes after flying. Charge until light on charger doesn't get any brighter when helicopter is unplugged... light comes on (dim at first) well before full charge. 10 minute cool-down after charge also a MUST. And, most important, when flying, as soon as you are unable to maintain altitude, land helicopter and power it off. Li/Po batteries should never be fully drained. Even one full discharge can cripple or ruin entirely your helicopter's battery.
hope this helps.. let me know,
r
Posted on Sep 12, 2011
SOURCE: so i have the syma
Make sure the drive shaft is seated properly. Gently, but firmly push it down towards the body both above and below bottom rotor. Also check shaft for any hair, thread or such thing that may be wrapped around it.
Let me know if you're still having issues, and we'll dig a little deeper.
PvT
Posted on Sep 14, 2011
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
I replaced the blades on my copter but it. Won't hover I changed all the blades and it just sets on the floor and won't take off.
did you put the blades on the right way
you will notice that the leading edge of the blade will be slightly curved and this curve has to be at the top of the blade so that as it is spinning it creates lift and so lifts the chopper of the floor
Nov 12, 2015 | Syma S111G Infrared 3CH Micro RC...
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
Trim problem. Won't hover ,just crash
Try to operate while holding it... Or have someone else holding it, if you can feel where it's want to go while sticks are in neutral, trim it the opposit way. Good lock Have you look at gyro gain? Try to lower it as too fast makes it instable.
Jan 03, 2014 | Protocol Manta 4-Channel Radio-Controlled...
My Syma 107 will not lift off the ground. It lifts a little bit and thats it. Its only a week old.
r u charging from the controller? if so put luthium aa batterys in controller the ones you have in there now may not be giving a full charge, you r turning the controller on when charging heli right? wait for the chareer light to turn back to green from red will tell u charge is done. u must have a computer 2 have posted this so charge ur heli from computer wait 4 it 2 light up red (the usb plug) b sure heli is off when charging the little swith should b forward toward nose of heli if it still wont lift off after a good charge b sure the top part of the blades are tight on shaft, its the two screws just under the top blades 1 of the 2 must b tight on the shaft or it wont get enough power if it is slipping, if it still wont lift off u may have a bad li po battery never run it way down!! always stop flying when u c the heli start to not have enough power to hover, always stop and let batt cool dn then charge, then after charge try 2 wait 4 a little bit b 4 flying 2 let batt cool from charging, i know it is very hard 2 wait, hoppfully u have not fryed the battery if u still cant get it e mail me and i will help u get up and flying good luck the s 107 is my main bird i work on them 4 friends all the time if i had it 2 look @ u would b fly n n 5 mintues my e mail is pznuraz@yahoo.com
Jul 29, 2011 | SYMA Toys industrial New Syma S107 Mini...
My syma s032 now won't hover consistently but moves up and down slowly of its own accord. I can compensate by continually moving the joystick. I did have a couple of crashes though they were...
Could possibly be weak remote batteries?
Also, the s032 has an incremental throttle (you should feel very light "clicks" when moving left joystick {throttle} up or down) that can sometimes make steady hovering a challenge. Syma helicopters are fairly durable, but crashes can make them kind of shaky. Be sure to quickly throttle down fully when you are about to have any kind of blade strike or crash. If you crashed outdoors, check to make sure no blades of grass or other foreign items are in near the gears, and check the shaft for anything wrapped around it that might be slowing one or both main rotors. (even a stray long hair can muck things up) Is it exhibiting any other symptoms?
Still getting similar flight time?
Hope this helps, let me know.
r
Jun 29, 2011 | SYMA Toys industrial Syma S032 Ready to...
My helicopter (SO32 Gyro) having previously worked perfectly now will only hover. I have tried recharging it but it makes no difference. I wonder if I have overcharged the battery and if it is possible to...
r
Feb 27, 2011 | SYMA Toys industrial Syma S032 Ready to...
I just got the new s032g . i can't stabilize itand it's lookl ike no gyros installed. when it's come up it's start to move forward. any help? thanks, Erez
Make sure that when you turn it on, you place it on a stable and LEVEL surface until gyroscopes sync up and internal red light (not red/blue flasher in nose) stops blinking. This sets level heading for helicopter. If gyroscopes sync when craft is not level it will be trying to correct and will move forward or backward. If helicopter is level and blinking red light inside stops blinking after powering on and it still moves and wont hover. Then you have a defective board and I would return it to retailer and ask for replacement.
r
Jan 23, 2011 | SYMA Toys industrial Syma S032 Ready to...
Open Questions:
See all SYMA Toys industrial Syma S032 Ready to Fly Gyro Questions
SYMA Toys industrial Syma S032 Ready to Fly Gyro Logo
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
