Question about Brother MFC-7340 All-In-One Laser Printer
My brother mfc printer is making a noise
Every time i print it make very loud noise
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
komguy
  • 2306 Answers
SOURCE: clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Posted on Jun 24, 2009
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
Brother mfc-290c print unable 73
hi
try to make hard reset
or download the latest drivers/ program from the site of brother .
some times they apdate automaticaly your programs - and some times it makes problems !!
bernard
http://www.rylwy.com/
Jul 07, 2011 | Brother MFC-290C Multifunction Color...
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
Clicking noise with MFC-8640D
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Clicking noise on power on and every print
This can be all that is pleased , main reason there is defect of lubrificant there where this it is necessary, recommend you to apply to nearest service.
Mar 05, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8440 makes very loud noise when printing/copying
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
Dec 20, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc8440 clicking sounds while printing
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Mar 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-7340 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
