Question about Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-FJ3M/W does not boot.
I have a sony vail vgn-fj3mw which powers up but does not boot. The power light stays on and the Hard drive button just flashes once and does not show up again. Nothing shows on the screen. Does anyone know what the problem is?
  • mal123wain Jan 14, 2009
    Thanks for the answer. I tried the hard drive externaly on another computer and it was working fine. I put another harddrive but the laptop did not respond. Just a 1 second of harddrive light was all I got. Is there anything I can do please help.
    Problem Solver:
  • 8 Answers
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Posted on Jan 11, 2009
My vaio van sz483N will not start following a hard drive replacement?
The HDD has not been placed correctly leading to a short circuit so the laptop does not switch-on . Remove the HDD and power-on the laptop if it switches on then need to check the HDD .
Jun 17, 2015 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
Sony Vaio VGN-SZ18GP Windows 7 shutdown problem .... when I shut down .... it gets stuck on the screen of shutdown but the "loading circle" is still running
This can be a sign of a memory failure, either the RAM is not clearing or the hard drive is on its' way out. Hold the power button down for 6 seconds for a "hard shutdown". Then restart and see if the problem persists.
Oct 13, 2013 | Sony VAIO VGN-SZ18GP/C, VAIO VGN-SZ420NB,...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
My sony vaio vgn-crc353 notebook stopped booting up. after pressing power button, it wouldnt go to light up the screen. it just stops where the power led and the battery led is on. at one instance, i noted...
Replace your hard drive. You are having a hard drive failure and need to replace it. If your computer is under warranty call sony and send it to them to replace the HD for free
Please rate
May 31, 2010 | Computers & Internet
Sony vaio vgn-fs8900p isn't booting
Most likely your hard drive has gone bad. It could be your RAM too. I know that you said you checked your ram one stick at a time. What if both sticks are bad? I would get some cheap (low MBs) sticks of ram that are compatible with your computer to see if your computer will start to run right with those in.
May 20, 2010 | Sony VAIO VGN-FS8900 Notebook
Laptop will not boot, Sony Vaio VGN CR220E, lights come on, don't hear the Hard drive start up, however. I get the clunks from the CD drive, but that's all.
Such problems happen when you have either faulty RAM or faulty Mother Board. Repairing MotherBoard Chip is a costly affair but replacing RAM is convenient and most probable solution.
With Regards,
Ankit
Oct 08, 2009 | Sony VAIO VGN-CR220E/P Notebook
Problems booting Sony Vaio VGN N250E
no more then likely it sounds as tho your hard drive went ..not the mother board.
Jul 23, 2009 | Sony VAIO VGN-N250E/B Notebook
VGN-NR220E won't boot up
Bad memory can cause a system to hang as you describe.
If it is accessible, remove the memory cards, swab them with cotton swabs and alcohol and try it again.
Don't put the cards back in while still damp if you use rubbing alcohol.
Aug 19, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Sony VAIO VGN-FJ270/B Notebook Logo
391 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
