Question about Kenmore Microwave Ovens
My 2004 Kenmore microwave oven, model 721.69252 over stove will no longer heat food.
All other functions work....clock, lights (inside and out), fan etc work fine but no heat so at the moment it is useless. Please give me some ideas to try to fix this. I am very handy with many tools. Thanks, Ron
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
  • 5 Answers
SOURCE: oven and microwave combo
Your microwave is plugged into an outlet built into the top of the oven. This outlet has a "circuit breaker" that trips when using the self cleaning feature. This is a design flaw that Jenn-Air/Whirlpool refuses to acknowledge. You just need to reset the breaker button that the microwave is plugged into. It's right next to the outlet.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Posted on Jan 04, 2008
  • 472 Answers
SOURCE: GE Spacemaker Microwave 5 years old Model
the magnetron may be faulty on this unit... the magnetron is what heats unit... there is also a thermal limit on this unit mounted behind the control panel and will require removing in order to check... unplug unit and remove two wires attached to limit about the size of a quarter and round in shape..check contuinity and should be closed... if it is then most likely the magnetron has failed... is a replaceable part sorta expensive and requires taking apart the cabinet and removing a few componets to get to the magnetron bolts/screws ...
www.sears.com then hit the parts direct link up at top of the screen enter your model number and will give you a parts diagram check availabilty and price on your part....
sometimes cost verses replacement is worth buying another one.... but can be fixed... most magnetrons have 5 year warranty goes by serial number of unit or installation of unit if your the original owner.... good luck to you
Posted on Jan 26, 2011
ynogami21
  • 670 Answers
SOURCE: My Magic shef over stove microwave will not heat
It seem that there is a problem with the panel board of your microwave. If you can try opening the panel and check if the wires are ok and in good condition. Check the continuity of the wires to make sure that they giving enough power to the panel board.
While you're at it check the status of the fuses as well. If knowledgeable enough and you have a schematic of the panel (usually came with the oven when you bought it) please check the status of the capacitors and the ic to make sure that it's not causing the trouble.
If those failed then a replacement panel would be the answer.
If you feel comfortable enough doing all that then you can ahead and try to fix it yourself but if you're not familiar with what to look for I would recommend you ask for help from a professional as microwave's have radiation that can leak out when improper covers are opened.
Try contacting these guys if you feel you are going to need some help.
1-800-424-2047
Thanks!
Posted on Sep 07, 2011
SOURCE: my kenmore elite stove model#790 the oven and broiler do not heat up but the fan runs
Since none of the burners or elements will heat, I recommend that you shut off the house circuit breakers for the range. Your symptoms point to a voltage supply problem. The range should have a double breaker (the two circuit breakers are probably connected together with a metal clip). The range clock control will light up if only one leg (L1) of that power supply is provided to the range. If the second leg of power (L2) is missing, then none of the burners or oven elements will heat. You could have a problem with the circuit breakers or the wiring on the terminal block at the back of the range. With the breakers shut off , I recommend that you pull the range out and check the wiring on that terminal block. Based on your description, you may find a loose connection or burnt wiring in that area. The image below shows wiring information for the terminal block and the junction box for the range. This information should help you check that issue. If you can find a wiring failure and restore a proper voltage supply to the range, then the stove top burners and oven elements should heat properly.If you find no problems with the wiring, then you could have a bad circuit breaker or a problem with the house voltage supply for the range. An electrician will normally need to diagnose and repair that type of failure. I hope that this information helps. If you need more assistance, reply with additional details. If you need parts, you can order them from the Sears PartsDirect website.If you get to a point where you need to have a service technician repair this failure, you can schedule service through this link: Sears Home Services .
Posted on Nov 27, 2012
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Does not heat anymore, power is going to unit, the clock, and fan work, light still works but it will not heat and makes a low growling sound when we try to run it. Help!
What you are describing is a problem with the magnetron and it has become faulty, that is the main part that heats the food, the growling sound indicates it is loading down the power transformer that energizes the magnetron. The repair cost will not justify the expense "costly" replacement of the microwave oven "cheaper" in the long run.
Jan 21, 2011 | Kenmore 80412 Microwave Oven
My kenmore clock, fan, and light works,but does not want heat food. What could be the problem?
It is probably a burned magnetron, sorry to tell you that a magnetron is the heart of the device (it is what produces the MICROWAVES) so it is almost the price of a new microwve oven.
You could ave it cheked could be just a fuse as well...
Dec 31, 2010 | Kenmore 62622 Microwave Oven
The exhaust fan works, the light below the microwave that shines on the stove top works. It appears to be functioning properly except that it won't heat up food. The GE Spacemaker Model JVM131001 is...
I'm all for fixing appliances but in your case I would suggest replacement. After 24 years of service the magnetron is probably only putting out half of its rated wattage. It could also be one of the reasons of the no heat condition.
Jun 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Our Danby DMW162-ORT doesn't heat up food. The digital numbers, inside light, clock and turning tray are all working.The fan is working but no heat. It's also making a whining/grinding sound that wasn't...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 15, 2009 | Microwave Ovens
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Kenmore 665.61629100 Microwave Problem
The 665 prefix on your model number is Whirlpool, but I haven't found the code "d" listed yet.
Can you set the cooking time?
If so, what happens when you press Start?
I'll post back if I find the codes or if you have other info and I can help further.
Oct 13, 2007 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
