Question about AT&T E2120 2.4GHz Cordless with Alarm Clock Radio Phone
AT&T E2120 flashing a warning check battery message after replacing the battery
Replaced the battery in my AT&T E2120 handset. Phone flashing a warning to check the battery. The charging light is on. Is this normal after a new battery installation?
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: "searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Posted on Jun 05, 2006
CORDLESSGURU
  • 106 Answers
SOURCE: OUT OF SERVICE MESSAGE
Hi J,
Apparently that one from Ebay looks nice but has issues (not uncommon). If you took it out of the box, charged it fully and its has garbled audio, then the handset or the base is defective, or both, but at least at this point you can get a handset to "communicate" with the base and the "in/use light turns on, when you try to access a line,correct? . If you get the "out of service" message when trying to "move" the "ebay" handset to the other base, it sounds as if the base station and handsets are "coded" and were married together at the factory and one handset won't interchange with anothers base. However, try this before you go the repair service route, or roll the dice with another fine product off EBay :). Unplug and power down both bases, the one from Ebay and your old one. Take the Ebay handset and set it in the charging cradle of your old base. Power up and wait three minutes. Plug dial tone in and give it a try. If it still says "no service" , and won't light the "in/use" light when you try to use it then it won't work with your base, or/and your old handset you lost is somewhere near and is still communicating with its base. Now if you lost your handset weeks ago, then the odds that it is still alive are pretty slim. But I have heard handsets in the warehouse beep for days til their battery dies. You can google cordess telephone repair for service. Good Luck. CG
Posted on Feb 14, 2008
sharna banna
  • 51 Answers
SOURCE: My battery won't recharge once it gets drained.
you may need a new phone because it has definetley worn out so yeah
Posted on Dec 19, 2009
  • 8404 Answers
SOURCE: Periodically, the phone will say Warning Check
Your battery is nearing the end of its useful life. If you replace with a new battery, you will likely solve this trouble.
Find replacement at a FixYa.com advertiser, Radio Shack, www.batteries.com or other file retail outlet that sells batteries.
Posted on May 16, 2010
Answering light keeps flashing when theres no messages
That might be the Voice Mail Warning Indicator.
On the D1680 and similar handsets, it is reset by:
1. press [menu]
2. scroll down to "Global Setup", press [select]
3. scroll down to "VMWI Reset", press [select]
4. scroll down from "No" to "Yes", press [select]
5. handset will chirp, blinking lamp goes out,
6. press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Feb 27, 2016 | Uniden Cordless Phone
Why is red light flashing when there are no messages on the machine?
1. press [menu]
6. press [END]
Oct 22, 2015 | Uniden Cordless Phone
Network unlock for samsung gt-e2120
Hi, You can get the unlock code for a Samsung E2120 from www.simpleunlocking.com/samsung-e2120/rs16wp9/ at low cost.
UNLOCKING STEPS FOR SAMSUNG E2120
Method 1:
1 - Switch ON your Samsung E2120 with a NOT ACCEPTED SIM Card.
2 - Samsung E2120 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2120 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2120.
3 - Compose : #0111*CODE#.
Nov 02, 2012 | Samsung Cell Phones
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
My uniden hanset stopped working. When I click on
Disconnect your phone from the wall and charger....Take out the Batteries and wait 2 secs...Replace batteries and recconnect phone ..see if this problem is still happening.
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Heres a site for more help:http://mycusthelp.net/UNIDEN/supportkbitem.asp?sSessionID=&Inc=1093&sFilA=Product&sFilB=Model&sFilC=&FA=-1&FB=-1&FC=-1
(Copy paste to browser)
Mar 08, 2010 | Uniden Cordless Phone
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
Aug 05, 2009 | Vtech mi6896 Trio Cordless Phone
What does a blinking "cl" mean?
I believe "CL"indicates clock. Change the clock settings at the lower right corner of the answering machine.
Apr 08, 2009 | Vtech 5.8 Ghz Handset Cordless Phone...
2 of my 4 vtech handsets keep giving me a 'check battery warning'
Try to reset the handset from handset menu, maybe the eeprom setting for low battery warning threshold have been ereased . Also check ,if the battery is the oregional battery for the phone.
Jan 21, 2009 | Vtech Lands Phones
V tech phone---"can't connect" message
Solved it by checking the GFI outlet in my kitchen closest to the phone---That was it! problem solved
Nov 29, 2008 | Vtech T2435 Dual Handset Cordless Phone
AT&T E2120 2.4GHz Cordless with Alarm Clock Radio Phone Logo
18 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
