I have a Warm Fusion 1500 Watt oil filled space heater. Does anyone know if you can have the thermostat dial all the way clockwise while having the temp knob in low?
3 Suggested Answers
  • 3 Answers
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
Posted on Jan 26, 2010
  • 6982 Answers
SOURCE: I have an older Delongi
Those were good little heaters. Problem is that by the time you buy the controls and pay for shipping, You could have spent another five dollars and gotten an entire new heater. I had a couple of those around the house and don't remember ever paying more than about $35. for any of them.
If you want to play with it, try contacting the company for a parts and price list!!
Posted on Jan 25, 2011
Ew6507l - nowhere near warm enough
only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
Dec 11, 2013 | DeLonghi 6507L Oil Filled Radiator Heater
Oil filled heater won't heat up. It does turn on and the light illuminates but no heat. I't been in basement for the summer.
Could be that the thermostat is disconnecting because it senses too warm.
Plug the heater to the wall, turn on the switches.
Turn the thermostat knob all the way to min. It should make a click sound and the heater should not get warm.
Turn the thermostat knob all the way to max. It should make a click sound and the heater should get warm.
If the heater is still not warming up and/or you don't hear clicks, then the heater has bigger a problem.
With the cheap prices of the heaters, it is not worth trying to have an electrician check it out. Just buy a new one.
Oct 18, 2013 | Midea Oil Filled Indoor Heater - USA, INC
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
How do you use the dial and what is it for
This heater has both a dial and a wattage selector. The dial is a thermostat, so it will turn the heater on and off as the temperature gets warmer and colder. Just like the thermostat on the wall in a house. The wattage selector switches let you pick how much heat goes in when the thermostat (the dial) tells the heater to turn on.
If you set the wattage at a higher level, the heater will use more power at once, but will turn on and off fewer times to keep the temperature determined by the dial setting.
If you set the wattage to a lower level, the heater will use less power at once, but will turn on more often and still use about the same amount of electricity.
So the dial really lets you pick how warm you want it to be in the room, and the wattage switches let you pick how often it turns on and gets hot. So this dial really determines how hot your room will be.
Feb 11, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
I have a Lakewood oil filled heater, mod # 7096. It heats, but not heat like it used too. I have checked the on/off switch, thermostat, and both seem to function properly. I have done a resistence check of...
No, the oil does not break down over the years of service. These units are made and sealed from the factory. The purpose is to make a unit that does not require repairs and will run for years. It appears that the TSTAT is not sending proper amperage through. My suggestion is to replace the unit as it costs more to repair then to replace.
Sorry for the bad news, but these units are just not meant for service, hence the price.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
No I never had any luck and the parts likely 1/2 the cost or more of a new one at wal mart and the heat element would still be old too
Dec 31, 2009 | Lakewood 5101 Oil Filled Radiator Heater
What is the lower dial for, what do the balls mean ?
The red dials (I think - I can't find a pic where they are facing forward to see them) should control the wattage you have the heater set at. You can set it at 500 900 and 1500 watts usually. The first dial turned on would set the heater at 500. Turning the second dial on will set the heater at 900. And having both on will set it at 1500. And of course the more watts the more heat that will come out of the heater.
Dec 29, 2008 | Lakewood Oil-Filled Electric Radiator...
Heating & Cooling Logo
275 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
