Heat pump ok the furnace works,but the outside heat pump will not come,but it dose work when i turn it to the cool side.we did have some snow last week of about 18''and it is gone now.why won't the heat side work?
  • 3 Answers
What type of furnace? strip heat....gas... I would check the reversing valve.Run the unit in cooling have someone switch the stat to call for heat....."Whooosh!!!" the reversing valve will switch over.Other methods of switching the valve , remove one wire, remove the nut and slide the solenoid off the valve will reverse. The switching solenoid can be checked magnetically by using a small screwdriver. Switch from cool to heat or heat to cool this way you can check if the valve is getting a signal .
Heat pumps are a fairly complicated simple device..... sometimes just switching the valve back and forth a couple times gets it unstuck. Remember air coming from the duct will feel cooler than air from a gas furnace .
Most customers don't think they are working when they really are. 100 degree heat is not that hot to 98.6 degree person who is used to 120 degree gas heat!
Posted on Jan 11, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Heat Pump makes a surging/buzzing sound every 20 seconds
You might have a short going to your reversing valve. Check the temperature of all three lines out of the valve. The one on the left should be cold and the one on the left should be warm hot. . Check voltage to the valve.if it fluctuates that might be the reason for the buzz.
Mar 04, 2015 | Heating & Cooling
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
My cozy floor furnace wont come on
NEED MORE INFORMATION. IS THERE A LED LIGHT THAT FLASHES A CODE?. IS THE THERMOSTAT OPERATING PROPERLY? IS THIS UNITS FLUE EXHAUST VENTED TO THE OUTSIDE? & IS IT FREE OF OBSTRUCTIONS?,
Dec 25, 2012 | Cozy Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
No heat
First figure out if your unit is a heat pump, (where the unit outside both heats and cools your home) or it may be a propane or nat gas furnace, it could also be a hydronic heater (the water heater heats the home) let me know what you find out.
Oct 30, 2007 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
