How to connect my tv, with Antsig AP592 universal remote?
SOURCE: i have brought a antsig
There is usually a way to program a remote control without the code.
!) Turn on the component you wish to program.
2a) If the remote has a set button press and hold the set button until the light blinks. 3a) Keep alternating between the component you want to program button and the power on and off button until the component turns off.
4a) press the set button and that should save .
2b) If the remote doesn't have a set button press the button of the component you want to program and the power on off button at the same time until the power button blinks. (usually 3-4 sec)
3b) keep pressing the power button until the component turns off.
4b) Press the stop button and that should save.
I hope this helps you.
Posted on Mar 13, 2011
  • 6 Answers
SOURCE: Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Posted on Mar 18, 2011
  • 6 Answers
SOURCE: Just bought an ANTSIG 4
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. I have only tried this with an LG TV. Hopefully it helps you out. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working. Maybe you'd need to press something else instead of TV for a VCR? But the trick is to be about 1mm away from the signal receiver. I literally put it in front of the red light of the tv.
  • 6 Answers
SOURCE: I have an Antsig Universal
Not sure if you've decided to throw your remote control away already or not. But I've only used option B only for an LG TV and it worked. My suggestion would be to turn your dvd player off and configure your TV first. I can't help with the split screen, sorry! The trick is the distance you put between the remote and the TV. When using option B, point your remote about 1mm away from the signal receiver on your TV! (where you see a red light or something) Took me around 1 minute or more. Just talk to someone on the phone while waiting for your TV to turn off. Remember, hold the "power" button down until you see a reaction!
  • 6 Answers
SOURCE: I have bought an Antsig
Have you tried the manual option? Turn on your DVD player. Press "TV" or maybe a different button for DVD players, then a red light on your remote blinks once. Then hold both the "up" volume and "up" channel button down until your red light is permanently on. Then whilst holding your remote control 1mm away from your DVD player signal light (usually red too), hold down the "power" button until your dvd player switches off. Then switch it on again and try other buttons. However, I've only tried this on an LG TV, but took me 2 days until I really put the remote in front of that signal light. Took about 1 minute or more while holding down the "power" button. Hope it works =)
What is the code for a Samsung blue ray DVD on a antsig universal remote
The code is in the antsig remote control if it is compatible. Use code search to find out. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jun 15, 2017 | Samsung Televison & Video
I need a remote code for my antsig universal remote I have a TEAC flat screen TV
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 14, 2014 | Televison & Video
I need the phillips code for my antsig universal remote
Codes to check with Philips are 0592,0879,0729,0629,0197. If you wish to get more codes to Philips brand with different other brand remote controls, check this link.
Feb 17, 2013 | Televison & Video
Antsig codes for hisense ap592
Universal remote codes to check up with Hisense Brand TVs are: 0073 0182 0216
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you want more details, check this.
Dec 27, 2012 | Brookstone 538744 Remote Control
Cant get my antsig ap592 remote to start up
1) Clean the contact batteries with special spray contact cleaner.
2) Retight the spring contact, for better contact batteries.
3) Resolder the wires from contact bateries.
4) Resolder the wires contact batteries,
5) Put again the codes and try again.
6) iF DOESNOT work,you must open the remote control for resolder any contact for cool solder.
sincerely. God bless you
May 07, 2012 | Televison & Video
Antsig AP593 Universal Remote Control Code for Sanyo LCD-40XR10F LCD TV
Hello
Try these codes.
004/ 013/ 049/ 108/ 110/ 180/ 209
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
Mar 09, 2012 | Televison & Video
I lost my lg plasma tv remote i brought antsig universal remote i need the code
These codes work on a LG 4750 with a Comcast three device Remote 11265, 10178, 10700, 10856, 11178, 11758, 11993
1346 ,0008 ,1346
Give credit to adreescheema@yahoo.com
contact No:00923015545637
May 27, 2011 | Televison & Video
I have an Antsig Universal remote and the booklet does not have the code for my VIVO tv or my AWA dvd. I tried doing option b where it scans for the code but it didnt seem to work. Now my dvd screen on the...
Jan 15, 2011 | One For All URC4110 Remote Control
Jul 17, 2010 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
