Question about HP Lc4276n 42 in. LCD Television
Top and bottom of screen cutoff on all aspect settings
I own an HP model LC4276N LCD TV which has good color and a clear picture,but the top and bottom of the picture is cutoff. I have tried all the aspect settings but the cutoff is the same. On an ordinary tv the vertical adjustment would normally take care of this problem. There is no such adjustment on this LCD. The unit is one year old.
    Sergeant:
    Novelist:
  • 326 Answers
There are several different zoom modes.  The one you describe is to make a 4:3 image fill the screen. It does this by zooming in (increasing the image size) far enough so that there are no bars on the side, but you lose the top and bottom as a result. Adjust  16:9 zoom option in your lcd and it will work properly. thanks.
Posted on Jan 10, 2009
  • 716 Answers
Press The Aspect Button On Your Remote To Adjust Between
4:3,16:9 Zoom1, Zoom2 And Panorama '
Thanks For Using Fixya.com
Sincerely,
Michael Scott
    Sergeant:
  • 378 Answers
Maybe u have selected the setting option --movie-- which makes the picture look like cutoff from both ends.just set it back to normal.
    Scholar:
  • 160 Answers
Have you tryed pushing the wide button? This button changes the screen to a panoramic or normal view. I usually have mine set on the panoramic view and nothing gets cut off and it is still a full screen unless you have a movie in that may stretch the picture more and even on the normal mode the top and bottom will be cut off.
Their seems to be a crake in the screen that makes seveal lines that goes from the top of the crake to the bottom of the screem. can this be fixed? or does t.v. have to be replaced?
no home fix for this one.
usually the service crew will replace the whole screen. (but keep the guts)
check if its worth the price to repair. likely replace the whole tv is cheaper.
Jul 01, 2011 | HP Lc4276n 42 in. LCD Television
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia loosing the top and bottom of picture.
Try the aspect ratio button on the remote or it is possibly an on screen aspect adjus
Aug 08, 2009 | JVC LT42P789 42 in. LCD TV
Where can I find a place to have my HP LC4276n LCD TV repaired? I live in Houston, TX.
J&K Electronics
723 W. MT. HOUSTON RD.
HOUSTON, TX 77038
888-674-1686
281-447-7679
Jul 09, 2009 | HP Lc4276n 42 in. LCD Television
Picture on Telefunken 72 cm TV expands beyond screen size
Your screen somehow got switched to theatre/cinema mode. There is a setting on the remote that attributes to aspect ratio. Sometimes it is called "ASPECT". Look for it, and press it until your original screen aspect shows.
Dec 15, 2008 | Apex Digital PF2020 20" TV
Picture is cut off
Try setting the set to 4.3 expanded on the aspect ratio. If that don't work try the other aspect ratio settings. That should make the picture fit the screen.
Jun 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Picture quality is terrible...not sharp and crystal clear
Set the aspect ratio to 16:9 and the top and bottom of the picture will reurn. Promise.
Try adjusting your contrast to help the filmy looking picture.
Dec 09, 2007 | Sylvania LC370SL8 37 in. LCD Television
HP Lc4276n 42 in. LCD Television Logo
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
