Question about Dell Dimension 2400 PC Desktop
Dell flat panel monitor -power button blinks green to amber - no
No picture
I have a flat screen dell mointor E198FPF flashing amber light would not show nothing but black so i bought another mointor but my other one tilted miss it the new mointor works great with my desktop inspiron zino 400 so i know its my monitor shows a padlock symbol on back of the old dell mointor help if you can thanks
Posted on Apr 29, 2012
    Problem Solver:
  • 8 Answers
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Posted on Jan 12, 2009
2 Suggested Answers
mrtiesi
  • 8 Answers
SOURCE: monitor problem
I would suspect that it's your video card on your computer rather than your monitor itself.  That's just a huntch.  If you can grasp your hands on another video card, I would certainly try that.
Posted on Jan 11, 2009
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Monitor problem
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
Dell Dimension 2400 PC Desktop Logo
338 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
