Question about Whirlpool Refrigerators
No Lights On my Whirlpool Side-by-Side GS2SHAXNT00, the lights on refrigator side are bairly flickering (mostly dark) and it sounds like the a transformer is grinding in the back of where the two lower lights are located. The lights on the control center are also out. It sounds like the compressor is working everything is staying cold. Thanks, Rory
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like you have abad electronic control board, its located behind the refrig, mounted to the left side(next to compressor) the machine will function ( with exception of lighting) heres the part number w10135090 retails for about $100, easy enough for you to change your self
Posted on Jan 11, 2009
My wife opened the refrig. door and saw a blue flash now all the lights in the refrig side are out and the temp gage indicator lights are out as well.
Blue flash sounds like an electrical short (spark) that blew a fuse or tripped a breaker.
Is the machine running? You need to unplug and check the switch that turns the light on and the lamp socket itself for frayed or broken wires befoe restting breaker or replacing fuse. Once your electrical problem is resolved you can reapply power
Jan 20, 2011 | Whirlpool GS6NBEXR Side by Side...
Side by side sub zero refrigerator: freezer is
still not clear. in your question you say refrig side is dark and not running, then you say you put a temp guage in it overnight and it's steady. So you DO have cooling in refrig? If it's just the lights, yes it could the switch or it could be the light bulbs.
Jul 16, 2010 | Sub-Zero Refrigerators
Light in refrig not working & blue indicator lights out also. Pulled switch & lights still out if I jump the leads. Is there a reset botton.
your motherboard in the lower rear area of the unit is bad,if you have recently replaced burned out lights in the refrige when these lights burn out it causes a surge on this control board and burns the circuit trace,hint:if you hear a rapid clicking noise in this area of the motherboard its a relay trying to latch,a bad board wont let it latch and the lights will dimly flash in the refrige compartment and the digital read-out may be out too
Jan 24, 2010 | Whirlpool GS6SHEXNL Side by Side...
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool refrigerator
unitsdworking though just no lights in refrig compartment??? if so i would pull unit out nad check laft side bottom of unit for contoil board, remove it and chances are you see a burn mark on one of the circuit, if so youll need to replace it
Feb 18, 2008 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
