Question about Canon PIXMA iP2000 InkJet Printer
Printer wont print
When I go to print an error message appears saying: Service error 5100. It tells me to turn off printer and try again but it didn't work. All I did was change colour cartridge as normal but now this is happening.
    Genius:
  • 2,985 Answers
Service error may mean- ink overflow chamber needs attention Check Canon Technical Support or go to www.fixyourprinter.com
Posted on Jun 07, 2007
Service manual
look up the printer tray sir.... if you see a lots of paper inside the tray removed it.. then try again printing... or else... try to change the printer mother board...
Oct 24, 2013 | Canon i80 InkJet Printer
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
I850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Jun 19, 2008 | Canon i850 InkJet Photo Printer
Canon Pixma MP150 service error 5100
sounds like an engine failure..from that code..is this under warranty, by chance?
Mar 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
My printer wont print
the only solution I can give you is run to the nearest trash can and slam that **** in there. hope solution helps.
Oct 30, 2007 | Cannon Canon i960 Photo Printer
Canon PIXMA iP2000 InkJet Printer Logo
153 people viewed this question
Clive
Clive
old marine
old marine
