Question about Infinity KAPPA 62.1I Car Speaker
I have a 2000 dodge ram truck with infinity speakers with amps on them I need to replace the right side one. where might be able to find one email me rush49erfan@yahoo.com
    New Friend:
You can bypass the factory amps to replace the blown speakers i dont have the wiring specs in front of me but you can google it or try the12volt.com
Posted on Dec 12, 2012
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Try the auto wreckers
Posted on Dec 01, 2012
  • 43 Answers
Remove the torx bolts from factory spkrs,cut wires,but connect new spkr wires to leads coming from factory amp,attach new spkrs and use zip-tie to hold factory amps to new spkrs.now your new spkrs are amplified which will make them perform and sound better then factory infinity spkrs. old installer trick,let me know how that sounds.good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Posted on Jan 14, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: Infinity Bass link keeps cutting out.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
Posted on Jan 16, 2009
2000 jeep grand cherokee with infinity system right side speakers all stopped working but all speakers on left side still work could it be a amp problem?
If you haven't already checked the balance on your steep do that if its ok then take right hand wires off off amp & concert them to right side if they work it's the amp if not you have a short in wiring on right side of car pull door cards off then make sure no wires are bare or touching together or earthing on body
Oct 29, 2016 | Jeep Cars & Trucks
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
2001 dodge ram left front speaker not working
Check your wires but static could be if you ran your twelve volt amp wire and your stereo to amp wire on same side.
Apr 14, 2013 | 2001 Dodge Ram 3500 Truck
Infinity wiring diagram
Robbie,
Sorry, your question is impossible to answer. First it is listed as 2004 Dode Ram 2500. Then you ask for a wiring diagram for Infinity. Infinity what??? What year? What model? Which SYSTEM for this Infinity are you needing wiring diagrams for?
Dec 25, 2011 | 2004 Dodge Ram 2500
I have a 1997 Dodge Ram 2500 4x4 Diesle 5 speed manual I have a factory radio with 6 disc. changer the radio works and so does the cd changer but I get very little volume Im sure its a amplifer problem....
To determine how your speakers are amplified you will need to know what speaker package is installed.
Usually Laramie editions come with Infinity speakers.
If I remember correctly the Infinity speakers have appliers on them.
My dodge truck is a year 99 2500 series, and I have already had to replace the door speakers. I used the cheap Walmart speakers. (6x9) They fit well enough.
Note: If your truck came with amplified speakers, non amplified speakers will only push what your radio can provide it in Wattage.
May 02, 2011 | 1997 Dodge Ram
What is inside of a 2000 Dodge Ram 3500 Van door, like the locks
Regulator and sliders for the windows Up & Down Movement steadiness, the door handle mechanism which links to the door-jamb cleat on the Right side as you open the door (where the riveted steel stamp is on the inside of the door jamb), your speaker and wires, the cowling and flange for the air movement to defog your mirror... what else do you need?
Dec 31, 2009 | 2000 Dodge Ram 3500
No sound from RF & RR speakers
run new wire to the speakers is what i would do but u have to do it to all due to there possibly being a pre amp in the vehicle.
Oct 24, 2009 | 1999 Dodge Ram
Where can I find a left side infinity replacement speaker for my 2000 dodge ram?
I bought my jeep cherokee infinity tweeters off an individual in Ebay. The speakers were brand new in a box, OEM and a lot less expensive that through the dealer.
Hope this helps... Good luck!
Oct 13, 2009 | 2000 Dodge Ram 1500 Truck
Need to get wiring diagrams
1988 Dodge Ram Charger Car Audio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6′ x 9′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
pls rate
Jun 23, 2008 | 1988 Dodge D-Series Pickups
Amp
if its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Dec 15, 2007 | Car Audio & Video
Infinity KAPPA 62.1I Car Speaker Logo
368 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
