Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer wont stop buzzing
After the dryer is done drying, it wont stop buzzing unless i keep the door open. and there is no toggle switch to turn it off.
  • ivo334 Jan 11, 2009
    Open the panel right below the dryer switch and disconnect the wire attached to the "b" that will cancel all buzzing. Make sure to unplug the machine first. I have a 98702 kenmore and thats how i fixed it.
  • 15,935 Answers
The ECU is faulty - or the timer.
Check/replace as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Dryer wont stop
if when you open the door and the dryer keeps running you have a broken door switch part 3406105 go here and look at part number 41
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11076712691/0582/0151200/10051141/00002?blt=06&prst=0&shdMod=11076712691
open the door,look at the right top,there should be a paddle there that if you push in on it you should hear a clicking sound,if not switch is bad.now if you mean that it won't stop when it goes to off then you could have a bad timer part number 3976577 and it's around 100 dollars
11076712691/0582/0151200/10051141/00001?blt=06&prst=0&shdMod=11076712691
go here and it's part 3 on diagram,try it on timed dry and auto cycle and see if it stops on either cycles
Mar 16, 2013 | Kenmore Dryers
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Kenmore dryer wont stop, just cycles through all the setting
Replace the timer if it continues through and past a timed cycle.
Aug 03, 2009 | Kenmore 62802 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
245 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
