Question about Sony VAIO VGN-NR120E/S Notebook
Was simply on line and screen went to "windows resuming"
I turned off computer and when i turn it on again, the screen keeps coming back to "windows resuming" with the 'circle' turning but nothing else happens. You can't get your mouse anywhere on the screen either. Help!!! I have tried to locate my exact model in your listing but can't so this one seems the closest. Mine says it's got Windows Vista Home Premium, model PCG-7142L, VGN-NS100 Series.
    Problem Solver:
  • 8 Answers
Try a repair from boot disk.... tutorial here
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Posted on Jan 11, 2009
My laptop screen goes black after being turned on. First the windows emblems comes up and it says resuming windows, then goes completely black.
Try holding down the power key to force it to power off. Power it back up again and you should get the Windows Resume Loader with the following options "Continue with resume" and "Delete resume data and continue with startup". I can't remember the exact wording of the options, it may be different but you need to select the later or second option "Delete resume data and continue with startup".
Sep 07, 2013 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My laptop screen is blue with horizantal lines. After I installed a graphics card driver everything went fine, but the next day the laptop's display started acting weird. So I turned off the laptop and...
The OS-loading screen is a stong indicator that thee is nothing wrog with your hardware, but it is a driver issue. You need to press F8 as your computer starts up and enter SAFE-MODE.
Windows 7
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
    Figure 11. Windows 7 Advanced Boot Options screen
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
In safe-mode remove & delete the drivers you installed. If you can, revert to your old driver set.
Jan 06, 2011 | Computers & Internet
My computer is having start up issues. When I turn it on it'll act like it's loading normally and then it'll beep twice. It'll go to a screen that will have several ERRORs on it and ask me to press either...
It may happen when CMOS Checksom error i.e error may happen due to keyboard failure. Please follow the steps to short the BIOS
> Open the Laptop back panel. Locate the CMOS battery, remove it & then with the
help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a
screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Now, restart the computer in normal mode. If still facing issues then I would suggest a full system recovery.
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 28, 2010 | Acer Aspire 5100 Notebook
I have a gateway nv5470u,it picked up virurs and went blank,,it would not come on,then one day i hit the turn on button,it come on a blank screen with a white line uptop to the lleft...
That means that the hard drive is not detected properly on the computer.
Start the computer and keep tapping F2.
You will get a setup utility.
Press F9 and hit ENTER.
Press F10 and hit ENTER.
Now restart the computer.
If u still have the blinking cursor on that black screen, u need to check your hard drive.
If u are gettng some other error in windows or just a black screen, try doing recovery.
Recovery will wipe off all your datas in the computer.
For doing it, keep tapping Alt+F10 as soon as u turn on the computer.
If u are succesful, it will give a message that windows is loading files.
Just follow the prompts.
Keep me posted on the status of the issue.
If that helps, dont forget to rate me.
Nov 09, 2010 | Computers & Internet
Canon mp530 prints black 1/4" line on back
But some time when you get the chance do clean the waste tank out.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 29, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Away from computer, screen goes black. cannot resume. have to turn off (reset) computer
It must have gone into sleep mode, Close your laptop screen and open it again, if it doesn't work get professional help
Nov 10, 2008 | Toshiba Satellite 1105 Series 14.1" Flat...
Computer not booting
Unfortunately it sounds like the processor fried. These are very prone to heat degradation.
Link to computer gate
Link2
Link 2 is to Geeks.com
Link 3 Take your pick
Your board supports Northwood/Williamette processors with HT
in 400/533/800 Front Side Bus
Apr 05, 2008 | ASUS P4S800-MX Motherboard
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Sony VAIO VGN-NR120E/S Notebook Logo
262 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
