Defy laundromaid does not turn both ways whashing. washing in ons big heap in drum
When on the washing cycle the drum does not turn fully both ways. That results in the laundry lying in one heap when it goes to the spinning cycle. the cycle then stops.
IrishDruid
  • 2712 Answers
SOURCE: Kenmore frontload washing machine doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Nov 07, 2008
barkencoa
  • 3463 Answers
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Posted on Dec 12, 2008
SOURCE: I have a Defy
my laundromaid electro logic 920 is making unususl noise when rinsing!!
tshepoflo06@yahoo.com
Posted on Apr 10, 2011
ZJLimited
  • 17970 Answers
SOURCE: I have a Defy Laundromaid
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 28, 2011
Chesc
  • 59 Answers
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
Posted on Jun 09, 2011
Defy Laundromaid Electrologic 1300 wiring diagram
Contact Defy directly and request the wiring diagram.
Feb 26, 2018 | Washing Machines
I have a Defy Laundromaid 1300m that doesn't let water in or start with the washing cycle need help please
Sounds like your inlet valve isn't opening. With it not opening the cycle won't start by default.
May 11, 2017 | Washing Machines
Defy Laundromaid electrogenic 1300 drum doesn't
Possible blockage in the waste pipe stopping it from draining quickly enough or lack of water pressure getting in.
Sep 27, 2014 | Washing Machines
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
