Question about Electrolux Vacuums
My EL8602 check brush roll light on
Don't know if i need a belt or what could be wrong
reddevil6
  • 1673 Answers
SOURCE: Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Posted on Sep 18, 2008
  • 5 Answers
SOURCE: Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Posted on Oct 27, 2009
Vac Belts
  • 701 Answers
SOURCE: Brush is not rolling. I have checked the belts
Unhook the belt see if the motor shaft turns by itself. If it doesn't then the motor is the issue. If it runs then its probably the belt or the brush roll.
Posted on Dec 01, 2009
SOURCE: hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Posted on Feb 15, 2010
VacuumRepair
  • 438 Answers
SOURCE: brush roll belt stops turning when in position to
I think I know what the problem is with your machine. It's a rather lengthy repair, and I'll be happy to photograph it for you (like I do on most of my Fixya answers), but I'd like to know before doing all of that if you still need help, or if you've already fixed it.
Thanks,
CJ
Posted on Apr 10, 2010
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
Change brush indicator light
If the light is not glowing it means the brush roll is not spinning. The belt may be stretched and need replaced. The brush roll may be installed improperly. The magnet in the brush roll has to be aligned with the indicator light for the light to work when. The brush roll is spinning
Mar 30, 2014 | Kirby G4 Bagged Upright Vacuum
Dirt Devil featherlite cyclonic belt comes off
What makes the belt come off?
1) Wrong belt. use only genuine DD belt. No generics.
2) Worn out belt. Sometimes a worn belt acts this way. Just because it looks good, does not mean it is good.
3) Belt improperly installed.
4) Brush roll not spinning freely. (replace Brush Roll
5) Brush roll is not installed properly.
6) Machine is worn out where it pivots between the body and the lower nozzle. To check (without a belt installed) see if there is a lot of play forward and backward between the nozzle and the main body. If so, once a new belt is installed and you are pushing and pulling on the handle the motor shaft comes out of alignment.
NOTE: the #6 problem is the rarest and usually is due to an extreme amount of use over years.
Let me know if this helps.
Dec 31, 2012 | Dirt Devil Featherlite Bagless Vacuum...
My shark rotator brush won't spin. How do I fix it?
Check out this Video
https://www.youtube.com/watch?v=qdznafE4uis
One of the most important parts of the Video - It's a great Video by the way - is the switch being shown at the 3:08 mark in the video. I recommend watching the entire video to see how to disassemble the Power Brush Assembly. Anyway, if that switch shown in the Video fails, it will prevent the beater bar (rotating brush) from working. It could be stuck on or off. Ours was stuck off and would not turn on. The switch did not spring back and click like shown in the video.
This happened on ours and a quick call to Shark Corp got a replacement Motorized Floor Brush Assembly on the way and a prepaid shipping label to send back the defective one.
They need your model number on the silver sticker and the date code on the power cord plug - code is on one of the blades that plugs into the wall. it is stamped into it. We are out the vacuum till the new part gets here, but I have to give them props for great customer service and an easy warranty claim process.e3779990-e534-4036-811a-dd038f1e3c30.jpg
Dec 08, 2012 | Vacuums
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
the thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
Oct 30, 2012 | Dirt Devil Breeze Bagged Upright
I have a bissell powerforce bagless.that is melting belts. i've cleaned the brush bar and put a new belt on only to have the new one melted again. i don't know what could possibly be wrong with it.
Make sure all the pulleys the belt attaches to are spinning properly, if one is stuck or not spinning fast enough that will easily generate enough friction to melt the belt each time you replace it. Might need to replace other parts, or clean out more than just the brushes.
Jun 15, 2011 | Vacuums
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Belt smells burnt
If the belt has melted then there's something obstructing between the brush, belt and dust channel. Check that the endof the brush roll is completely clean, check that the brush roll rolls easily with your hand (obviously don't plug it in or switch it on when repairing/inspecting) If you can locate the motor shaft pin make sure that it rolls easily - if not then the motor may have seized up which will need professional repair. Also check that the filters are clean and the hoses are clear.
Mar 22, 2009 | Dirt Devil M085850 Featherlite Bagless...
Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Mar 11, 2008 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
1,145 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
