Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Manual for admiral HMG 65158
Does not make ice
4 Suggested Answers
  • 1314 Answers
SOURCE: Need a water filter for my ice maker
you can go to any appliances parts store and get an in line filter it in stalls in the incoming water line before it screws on the water valves comes with instructions if you get the kit
Posted on Jan 14, 2008
aborcass
  • 2651 Answers
SOURCE: Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Posted on Oct 26, 2008
SOURCE: Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Posted on Dec 06, 2010
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
How do you turn off the ice maker in a 21.6 cu ft HMG 62184?
If there is no switch then unplug the harness.
Jul 23, 2014 | Admiral Refrigerators
How do i remove an ice maker from an admiral hmg 62184
Most have a multi-connector electrical plug and a couple of screws that the ice maker hangs on. Disconnect the connector (most squeeze somewhere) and then loosen the screws. You may have to stick your head inside to see them. The water just 'falls' into a trough and thence to the chiller.
Jul 23, 2014 | Refrigerators
Icemaker does not eject ice all the way so it freezes up on unit
The model number you provided is not a valid model number. Please verify the model number.
Mar 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
I have admiral refrigerator HMG 21164 and it is stop making ice
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 10, 2010 | Refrigerators
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
54 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
