Question about Lanier Office Equipment & Supplies
How do I get Lanier LD540C copier to resume running after inserting new toner cartridge
I inserted new black toner cartridge when machine stopped due to toner out - machine continues to display add new toner
SOURCE: Replacing of new Cartridge problem
good day sir
I am Josco and my Email:oyas20102005@yahoo.com.
I have a lot of Sharp Copier but there is one that is giving me comcern coming out with a code (showing H & 4) and i can not work with the copier Sharp Digital AR-5316. please what do i do and it is the newest copiers among all, please i will be very glad to recieve a code so as t clear the interupting showing H & 4 on the copier.
Thanks
Josco from Nigeria.
Posted on Nov 05, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Problem with changing the Toner Copier Cartridge
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Posted on Nov 07, 2008
firecontrol7
  • 6161 Answers
SOURCE: Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Posted on Jul 25, 2009
SOURCE: We are getting a black edge on one side of the
Make sure you have the plastic seal on the toner bottle. The seal prevents toner from spilling inside the machine.
Posted on Mar 12, 2010
santosj27
  • 263 Answers
SOURCE: I have a lanier ld122 copier/fax. It told me to
First of all check if the doors are well closed.
If everything is well closed you can have several problems:
1º Toner supply defective.
2º TD sensor defective
3º Development unit defective.
If you don't have technical training i advise you to call the provider.
Posted on Feb 28, 2011
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
Why after we change the toner it will not print
after refill the toner may be bias charging roler is not proper fiting
or toner cartridge is not proper insert
Aug 18, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Full waste toner bottle Lanier LD540C
The boys at the office figured out how to get out and empty... Thanks for all your input... I had sent it on to them.
Jan 21, 2013 | Lanier Office Equipment & Supplies
Hp laserjet 4100 show message "Toner out". I can't print anything. Help me!!!
TONER OUT
The toner cartridge has run out of toner.
Depending on how the printer has been configured, it will either continue to print or stop.
Due to the resolution of the toner level sensor, it is possible that a small amount of toner (less than one percent) might still be present in the cartridge.
1. If the printer has stopped, you can resume printing by pressing GO for each job.
2. Replace the toner cartridge.
Jul 14, 2011 | HP LaserJet 4100 Printer
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
Dec 28, 2009 | Office Equipment & Supplies
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
I have a lanier lp-138c that is giving me a black toner low message on brand new cartridges... Tried 3 different cartridges and at first they register and then to the toner low...
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Apr 14, 2009 | Lanier Office Equipment & Supplies
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
