Question about Creative Labs I-Trigue L3500 Computer Speakers
Can I connect my creative i-trigue L3500 to my digital tv?
  • wendell_shep Jan 11, 2009
    So, I set this premium sound system up on my new computer and listened to live streaming Hearts of Space...samadhi..
  • Anonymous Mar 29, 2014
    owners manual
    President:
  • 1,179 Answers
No these speakers are computer speakers only. Sorry.
Posted on Jan 10, 2009
NEED CORRECT DRIVER FOR SPEAKERS SOUND CREATIVE L3500
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select
((appropriate speakers)) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 16, 2011 | Creative Labs I-Trigue L3500 Computer...
Tip
Install Creative I-Trigue 2.1 3300
I need to install Creative I-Trigue 2.1 3300.
on May 22, 2008 | Creative Labs I-Trigue 2.1 3300 Computer...
I broke my end of the volume control cord. i would like to know if it is easy to fix, or where i can buy a new volume control for a Creative I-TRIGUE 2.1 3300
You should go to nearest electronics technician and easily they can change V/C or manege with equivalent another v/c .There will not be no effect, if that guys work with care.
Or youn can purchase from ebay.com or
http://www.shopzilla.com/Creative+Labs+I-Trigue+2.1+3300+Computer+Speakers/search
Regard's
Shibuda
Jan 03, 2011 | Creative Labs I-Trigue 2.1 3300 Computer...
I have a Creative I-Trigue 3400. The volume keeps braking up like a loose wire can I find a replacement volume control.
Same with my unit!!!! Did you ever find a replacement????
I contacted Creative and they said they don't sell it! :@
Aug 13, 2010 | Creative Labs i-Trigue 3400 Computer...
It won't work! i plug it into my computer and when when i turn on the speakers, i can hear the *spark* of the power flowing through it but when i hit play there is no sound! what's wrong? i tried plugging...
You have your speakers pluged into the speaker jack, corrent? There is a mic jack there as well.
Do your speakers require external power and they are turned on and the power supply is hot? Have you tried these speakers with any other sound source?
Dec 28, 2009 | Creative Labs I-Trigue L3500 Computer...
How to connect Creative Itrique 3200 speaker system to my audio video receiver
You must have the phone jack to RCA cable. The phone jack will be connected to your creative labs then the RCA on your audio video receiver.
Sep 14, 2009 | Creative Labs I-Trigue 3200 Computer...
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
Broken Volume control
the stereo jackbus is stuck in headphone modus
unscrew remote and open up back part of stereo-connector repar switch and reassemble
Apr 27, 2009 | Creative Labs I-Trigue L3500 Computer...
Volume button doent work
So replace the non working control.
Aug 31, 2017 | Creative Labs I-Trigue L3500 Computer...
Creative Labs I-Trigue L3500 Computer Speakers Logo
202 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
