I require a users manual for a Model SMCC1221Y Mirage mini-split a/c unit
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 674 Answers
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
Posted on May 03, 2010
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
Rfl-0601EHL manual
You should be able to download the users manual on the carrier web site or just type in the manufacturer and model number with the words user manual. That should bring up a lot of links for downloading the manual in the PDF format.
Aug 27, 2014 | Carrier Heating & Cooling
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Air-Con Mini split --gives error code 4 shuts down after 25 minutes
Hi Emanuel,
Your out door unit could be very dirty or the outdoor unit temperature sensor is out of position.
May 04, 2014 | LG LS-K1830CL Cool Mini Split Air...
Need a manual for a LG split system
You should be able to get a service manual from the manufacturer online and down load it? Or go to where this unit was purchased and they should be able to help you.Get the model, serial, and product numbers from both indoor and outdoor units to take with you. The more info you have the better. The outdoor serial number shows the manufacture date.Have you removed the excess panel on the outdoor unit to see if a manual may be inside? they sometimes put them there instead of handing them to the owner. Good Luck!
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Where can i get manual of the part, reference # and troubleshooting of Sanyo Split system model#KS1271
Here is links for all the manuals for your unit.
http://www.sanyohvac.com/docs.php?id=12KHS71
The following are located at the above link:
  • 12KHS71 Dimensional Data
  • 12KHS71 Installation Manual
  • 12KHS71 Service Manual
  • 12KHS71 Submittal Data
  • 12KHS71 User Manual
Aug 18, 2009 | Sanyo 12KHS71 Split System Air Conditioner
I have an Amcor 18000 BTU Mini-Split A/C with Heater and Remote. It has never run more than two days and then I get E4 error code. It is difficult to get anyone to service these units in rural areas. I...
CLICK HERE for the manufacturer site and your owners manual.
E4 is an "Abnormality of Outdoor Unit."
This could be anything from a blown diode to low refrigerant.
Any HVAC repair company should be able to test the unit.
Thanks for using FixYa - please accept this answer to remove it from the work queue.
:D
Jul 08, 2009 | Heating & Cooling
My mini split does not run
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
Mar 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
