Question about Refrigerators
Westinghouse freestyle all fridge model RP342 cyclic defrost 340 litre
Would like a manual
  • ksmith61 Jul 03, 2017
    We have a Westinghouse 340 litre model RP342 fridge only the fridge is freezing everything on the lowest setting
3 Suggested Answers
  • 400 Answers
SOURCE: Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Posted on Mar 11, 2009
SOURCE: our westinghouse rp342 cyclic defrost
defrost element is cactus
Posted on Feb 21, 2011
I need a wiring diagram for the RJ532S freestyle westinghouse fridge. The defrost timer is dead and its in defrost mode
We do not have wiring diagrams. Please contact the manufatuer for a service manual
Feb 02, 2012 | Refrigerators
Im after a manual for westinghouse freestyle fridge RJ422T-R
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Oct 23, 2010 | Refrigerators
Westinghouse freestyle fridge. Fridge compartment not staying cold, freezer compartment working fine.
likely a malfunction somewhere in the defrost system, i.e., the defrost timer control, the defrost heater assembly, or the defrost bimetal thermostat
Mar 01, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Mar 11, 2009 | Refrigerators
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not working
sounds like the defrost system is defective, frozen. possibilities are fan in freezer wuit or defrost heater open or defrost timer bad. try these first, if not fixed call.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
