Question about Bosch Dishwashers
Is bosch dishwasher model SG145E12GB/23 still available
I want to know how much this dishwasher costs
4 Suggested Answers
SOURCE: Our Bosch dishwasher will not
can you hear humming?try taking out the screen filter and there is a torx screw that you can see, remove the screw and see if there is anything in there when you remove the panel.you will see the drain impeller try turning it by hand. if it is siezed then you will have to replace it.try putting it back together and try it again.
let me know.
Posted on Nov 11, 2008
  • 82 Answers
SOURCE: Dial Timer sticks between wash or rinse modes
Hello. Is the water getting hot? Usually the timer won't advance because it isn't getting a signal from the thermostat that is on the bottom of the tub, so it thinks that the water isn't hot enough to go through the rest of the cycle. That is if the water is hot. If it isn't hot then you may need a new heater. You may or may not need a new timer. Try the thermostat first because that is usually the thing that goes out and it is less expensive than the timer. You can order it from www.coastparts.com or www.marcone.com .
Let me know if you need anymore help.
Posted on Dec 08, 2008
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
Error 23 in bosch dishwasher
E23
Winding resistance of drain pump fault.
The controlled has detected a break or short in the drain pump wiring. Many of these dishwashers use this pump which is a cheap compatible one.
Dado
Jan 29, 2015 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher does not drain
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire!  Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment.  We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service!  Hope this helps!
Oct 03, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
My Bosch made a moaning sound and never got water to wash dishes. I tried to cancel the cycle and it would not cancel. I am guessing I have a bad controller? Can you tell me how much that piece would...
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 10, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch has discontinued making the front flip tine insert for the bottom rack. I have two broken in my Bosch dishwasher. Can I substitute another manufacturer's part?
Thanks!
Sep 07, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch dishwasher will not drain. Model number is SHY56A05UC/23. Help!
let me know.
Nov 11, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher Side Hose
The hose on the right is a breather and should not be connected.
Sep 17, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
96 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
