Question about Cannon Office Equipment & Supplies
Check document error on canon mf4320-43-50 wont print
I have a red flashing light and the screen says to check document and it will not print. how do i fix this
  • 25 Answers
SOURCE: printer stops printing half way down page
Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Posted on Jul 08, 2008
SOURCE: brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Posted on Feb 01, 2009
MIlfordPrint
  • 90 Answers
SOURCE: please show me step by step to fix error 5110 in
This is a carriage error.
1. Printhead is stuck to the docking area either because some old ink has become like glue.
2. A piece of paper got over there and is jamming it.
3. The spring is weak and is not pulling the docking area down.
4. The Purge unit has failed and needs to be replaced.
Turn the printer off and then slide the printhead to the left and use a flashlight to see if you see any paper stuck around where the two sponges that where sitting below the prinhead or if it just didn’t lower like it should have.
Posted on Oct 03, 2009
pineworks
  • 4041 Answers
SOURCE: Error 6500 on a Canon MP500
Hello there
Just in case it a bit of papper or other in there try.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 21, 2010
  • 53 Answers
SOURCE: flashing red light wont print
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
Posted on May 19, 2010
What is the meaning of the Red & Blue flashing lights on the printer?
Now your printer in Service Mode.
It's time to reset the printer.
Apr 09, 2016 | Ricoh Aficio SP 100 e Laser Printer -...
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Nov 17, 2009 | Canon imageRUNNER 1023N Black and White...
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
63 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
