Question about RCA F32650 32" TV
I have an RCA color television model # F25653BC. It sat in storage for two years. We got it out and it works except there are narrow bars across the screen all up and down the screen. What is the solution for this? Can it be fixed?
  • 108 Answers
Sounds like what we call "jail bars" if this the case replace the screen cap. It should be around the flyback and rated at 200 volts at least
Posted on Jan 10, 2009
How do I fix the red color on my RCA D52W17 HDTV ? Everything is real clear on the TV but I only get blue and yellow colors, I don't seem to get red. How do I fix this????
if your supplying an RGB signal to this set from a cable or sat box and not using its built in digital tuner id check the connections of the "R" (red) cable input this might have come disconnected
Sep 23, 2015 | RCA Televison & Video
The tv sat in storage for over two years now it wont turn on but the power light on the power button will blink
The most likely case is the CP150, CP120 and CP114 Capacitors have discharged and need to be replaced.
Sep 19, 2010 | RCA HD56W66 56" HDTV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Thin lines across the screen
This is a vertical problem
could be bad soldier bad caps or a burend resistor in the verticl section.
vertical repair kit cost about $39, but youl need a tech to do the install.
tv shop should repair for about 60 to 80 usd.
regards,
daniel.
Jan 10, 2009 | RCA F32650 32" TV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
Rca jack input very distorted
This is probably a short in the TV, most likely a ground problem.
Oct 19, 2007 | Hitachi 50UX57B 50" Rear Projection...
RCA F32650 32" TV Logo
95 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
