Question about HEALTHRIDER R65 Treadmill
Healthrider R65 does not work, only the up incline button works, what's wrong?.
No buttons on the control works but the up incline button. Stop button only makes a beep when touch.
  • mytm Ai Nov 30, 2012
    I ordered the Control Board from ICON and replace the old one and same problem. All light are on, no buttons works. Stop button beep and up incline button beeps when touch. Any helps?.
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: my belt wont rotate
The serial number decal should be in front bottom left hand side on the frame opposite the power cord. I would not worry too much about the serial number that is used for tracking their units. It sounds like the motor control board may have failed, but they may have you do a calibration to see if the board has actually failed.
Posted on May 29, 2010
ercupa190
  • 12223 Answers
SOURCE: my healthrider s300i softstrider treadmill
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Posted on Dec 13, 2011
ercupa190
  • 12223 Answers
SOURCE: My son folded my healthrider s300i while it was in
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
Healthrider 15.5 won't run,motor makes alittle grunt,turns alittle but won't run,incline motor works
hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Jan 10, 2014 | Exercise & Fitness
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
May 11, 2012 | HEALTHRIDER R65 Treadmill
My belt wont rotate
May 28, 2010 | HEALTHRIDER R65 Treadmill
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
HEALTHRIDER R65 Treadmill Logo
52 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
Matty Piilo
Matty Piilo
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
