Question about Comfort Products Heating & Cooling
Heat pump takes many trys to start compressor
Heat pump takes from 1 to 10 trys to bring the compressor on. When it does come on it is really noisey and runs forever before the stat is satisfied. Stat is in a ok place where it senses the whole house and out of the sun. I think the problem is the dual capacitor for the fan and compressor, the fan has no problem coming on. Could you give me some other things to check?
  • 700 Answers
Do the thermostat have a time delay on it? most digital ones do you may have to get one if thats the case. Also are there start components on the unit? I've had top add them due to the newer units hasve nonbleed txv's and have a hard time starting up because of them. ans if oyu can see if there's a crank case heater on the unit becaause refrigerant migrates to the coldest spot and the compressor can have all the refrigerant inside of the can mixed with the oil. goof luck
Posted on Jan 12, 2009
Why doesn't the compressor start in the heat mode
Is it a heat pump? Is it a heat pump stat? Is ambient temp high enough to allow heat pump to run?
Sep 11, 2014 | LG LP153HD3A - 14,300 BTU, R410A, 9.4 EER,...
Panasonic heat pump
Sounds like that's the relay clicking to run the blower motor .Check on your unit outside and see if the compressor is short cycling ,meaning it would run ,stop ,run ,stop .
If that's the case you have a bad install .
Maybe unit is shutting off on low pressure meaning no refrigerant. If that's the case you have a leak in the system that need to be fixed
Jun 01, 2017 | Heating & Cooling
I have a 5 ton york Heat pump that I notice the compressor is too loud and noisy, what do you think is causing it?
Many possible reasons. I assume the compressor is running and hopefully is pumping freon as it is supposed too. If it is just noisey and no other problems with unit it could be worn out compressor mounts. if the compressor sounds rattley then it could be getting ready to seize due to internal wear. May be a good time to let a technician take a look. Hope this helps.
Feb 11, 2011 | Carrier 38CKC036 Air Conditioner
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
Heat 2 keeps comming on my tru temp thermostat i think this is emergency heat and costing me money could the heat pump be bad
Hi, on a heat pump thermostat, some will have emergency heat, and aux heat. You have 2-stages of heat on this unit, strips, and the compressor with reversing valve. You need to go to the outdoor unit to see if you can hear of remove a panel and feel if the compressor is running when this light is on. When the 1st stage can't keep up when the outdoor temperature drops, the second stage will kick in to help warm up the home. But on the other hand, if the led light is on, and the compressor is not running, you are running on electric heat only, as either your compressor has failed bringing on the emergency heat, or you may also have a faulty run capacitor that starts the compressor. This is what you will need to check, the compressor for operation. You may need to call a tech I am afraid if the compressor is not running. It may have died on you, but there are several things that can keep a compressor from starting, run cap, bad time delay relay, burned off terminal to the compressor. You can check these things if you are able to do this. Shut off power, remove panel to the controls outdoors and give it a good look, only if the compressor is not running. The run cap will be a silver type can looking part with 2 to 3 terminals coming from the top. If it is bad, you can sometimes tell by looking at it to see if it is leaking oil, swelled up, deformed in anyway. If you see this, you can get another at a appliance parts house. It will need to be the exact rating, may be 370 volts x 55 mfd, or 440 volts by 35, depends on the size of your unit. Check the compressor terminals by removing the cover, 3 wires, R, S, and C. Just squeeze the cover and remove it to check for a wire burned off, again, only if the compressor is not running. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
PS, there are many sizes of capacitors, so draw you a diagram on the wiring before you remove it!
Dec 21, 2010 | Heating & Cooling
I am getting hot air instead of cool air from my heat pump when it is in the cooling mode.
The problem is in the thermostat wiring. Y1 on an air conditioner, brings on the cooling. On a heat pump, it brings on the compressor, which generally fails to heat mode. The O wire operates the reversing valve, which brings on cooling. If these wires are reversed, or not hooked up, you will not get cooling.
Jul 12, 2010 | Goodman CLQ36AR49 Air Conditioner
My unit has been running all day. set on 75 degrees and still only 65 in the house
If this is a heat pump depending on the outside temp. it may not bring the temp. up. It is really not efficent to run a heat pump below freezing or near freezing.I suggest running the Auxillary electric heat if. Most heat pumps have auxilarry back up electric heat banks installed in them.
Dec 26, 2009 | Heating & Cooling
On a coleman heat pump DRHS0421CB when the thermostat call for heat the heat pump compressor and fan start for an instant and then they stop and a failure message shows up on the thermostat. This works the...
If both the fan and compressor are going off the problem would be in the low voltage side a safety is opening. Probably low on refrigerant. You need to check refrigerant pressure when the unit is starting, if the pressure drops below 60 psig the low pressure switch will open and shut the compressor and fan off.
You really need to have a service technician check the system out for you.
Nov 22, 2009 | Dehumidifiers
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Heating & Cooling Logo
47 people viewed this question
Top Comfort Products Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Comfort Products Heating and Cooling Expert? Answer questions, earn points and help others
