What is the name of the toner cartridge for Canon h12425
2 Suggested Answers
  • 5 Answers
SOURCE: i have a canon h12425
Try and clean the laser glass. It should be right above where the toner cartrige slides in.
Posted on Oct 18, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
I have an old Canon NP1020; do not have an instruction book. Can I add toner powder somewhere, and if so where? If it needs a cartridge, where does that go? It prints, but faint.
Hello, my name is Steve.
Yes, this table-top copier does take a toner cartridge. Canon Part number is: Canon 1369A009AA
This can be purchased anywhere (limited stock....not a top item on a supplier's shelf)
The re lease is located on the side. Be careful on how it is unloaded and re-loaded, it can be messy.
I hope this helps, Steve
Aug 12, 2015 | Canon Np1010/20 Copier Toner For Np 1010,...
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
I cant get the toner cartridges in my canon c ir 2050 to go back into the copier
Try these steps.
  • Pull out of the front cover of the Canon 2200 so that it flips down and exposes the inside of the machine.
  • Remove any toner cartridge already in the machine by pressing down on the blue lever located near the bottom right of the inside of the machine. Then grasp the toner box right above the handle and slide it out until it stops.
  • Hold the new toner cartridge in both hands and shake it from side to side a few times to loosen up the toner.
  • Orient the toner cartridge so that the flat surface is facing downward and the small handle at the end of the surface is pointing toward you.
  • Place the toner cartridge on top of the toner box. Push it back in as far as it will go and then press down on the cartridge until you feel it click into place.
  • Pull back on the small handle on the top of the cartridge. A thin separator sheet between the cartridge and the toner box will come out. Continue to pull until you see a stop sign on the separator sheet.
  • Tap on the toner cartridge to cause the toner to vacate the cartridge and fall into the toner box. After you have tapped it a few times, push the cartridge handle back in. When the handle goes all the way back in, you will feel the cartridge unlock from the toner box.
  • Remove the empty toner cartridge and push the toner box back into the machine. Pull up on the blue lever once the box is all the way in. Close the front cover to the Canon 2200.
Hope this helps.
Jun 29, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
Canon monochrome laser LBP3108b printer cartrige can be refill?
I would not advise on refilling a toner cartridge, the toner power is very fine and you do not want to breath in this toner powder.
You can purchase a new toner cartridge or a recharged toner cartridge these are cheaper than a new cartridge.
You can get a few more print pages out of a empty toner cartridge by shaking the toner cartridge in a horizontal position and inserting back into the printer.
Dec 04, 2010 | Canon LASER SHOT LBP-2900 Printer
PanaFax UF-780 toner error.
If you mean a 788, there are moveable tabs on the front top of the cartridge that trip switches. Move them around.
Several companies have their own brand names on Panafax's. Their toner won't work. Kyocera must be kyocera Toner, Canon must be Canon toner, etc.
Aug 05, 2008 | Office Equipment & Supplies
Toner Cartridge
Mine is a single cartridge system. The black cartridge that looks like it holds the ink is the toner cartridge. Replace it with cartridge E40.
Jun 12, 2008 | Canon PC-920 Black and White Copier
Canon mf4150 "Toner not set" Error
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go. Our IT man rocks!
Dec 11, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
535 people viewed this question
jasbo
jasbo
