Question about Poulan 2550 Woodmaster Chainsaws
I have a 2550 Poulan 2.5c.i. saw. old gas line rotted out. trying to replace with new line. Problems is from gas tank to primer bubble there is a small fitting that the filter in tank ties to and then under the carb the fuel line ties onto the other end of fitting and goes to the primer bubble. when you put the fitting in the tank and out it into the hole to go top the bubble it doesn't clear enoungh to conect line onto it. How do yo get the two lines together onto this fitting?
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have a poulan pro 210 chainsaw both fuel lines
This should help:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This too:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
I think this is your saw please ensure I am correct.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw it can be found here:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Take some pics first then a small sample of the different fuel lines to your local chainsaw seller. A little extra is agood idea, I have not found a good fuel line stretcher and I have been looking. Probably a good idea to replace the fuel filter too.
Posted on Jan 16, 2010
  • 4088 Answers
SOURCE: I need a diagram to see how to replace the fuel
The large hole in the tank brings a line from the filter to the upper carburetor fitting. The lower carburetor fitting goes to the primer inlet (which is found by plug and try). The short line from the tank goes to the outlet of the primer. With fuel mix in the tank, try one of the ports in the primer with the line from the carburetor. If correct, the primer bulb will fill with fuel--otherwise, try the other primer port and see if fuel will come into the bulb. This may take over 6 pumps if the carburetor is empty of fuel. Did you check the fuel filter for plugging? If it was ok, and with new lines, fuel should pump into the primer provided the carburetor is not plugged itself. If the problem seems to center on the carburetor, be sure to check the diaphragm in the lower chamber for flexibility--no holes or cracks. Also, there is a very small filter screen in the mid-body section that may be plugged. Use spray carburetor cleaner to clean the carburetor inside and out. When you get fuel to come into the bulb, the short line from the tank goes to the empty port. Hope some of this helps!
Posted on Jul 23, 2010
197jacobs
  • 226 Answers
SOURCE: I have a 2250 Poulan. The fuel lines have been
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Posted on Dec 29, 2010
2strokeJim
  • 577 Answers
SOURCE: Poulan chain saw model #2025 - fuel lines dry
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Posted on Oct 12, 2011
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan pp4218avhd chain saw that won't sart. I have cleaned the spark arrestor & the air filter. I have replaced the spark plug with a correct gap and checked that it is getting a spark. I...
I have this saw and really like it. Does the the primer seem to work? Most problems on these saws can be traced back to cracked fuel lines. Either tank to primer, primer to carb, or carb return back to tank. I would recommend it the saw it more than 3 years old to replace all the fuel lines. Total cost about $5. Buy your fuel line at Ace Hardware.
May 05, 2010 | Poulan PP4218AV 18" Chain Saw
Primer bulb will not fill
This answer assumes you've put gas mix in the fuel tank.
Unless the saw is new (and possibly even if it is) there are only three things which can cause this:
1) The primer bulb is split or has a small hole in it (they rot and split often, but are not much trouble to replace)
2) The line between the bulb mount and the fuel tank is split or has fallen/been pulled off (this frequently occurs as well)
3) The fuel tank filter has trash on it and is preventing the prime. (this is harder to check and/or fix, but not impossible- and all of these are cheap!)
Dec 26, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
I have a Poulan 2450 thats not getting any fuel, I drained the fuel tank. When I looked inside and the fuel line,the white filter and the gromet which goes from the inside to the outside of the tank was...
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Typical fuel system:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best.
Poulan.com
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
When I prime my cainsaw ,gas leaks from the side near the handle. I usually prime it by tipping it on the side and depressing the gas bubble. Where the gas drips out then is on the side; the side is...
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number)
Poulan.com
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages.
c828c16.gif Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have a Poulan 2150 2.1 chainsaw. I have no manuals. All of the fuel lines are dry-rotted and need to be replaced. How can I do this myself?
An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
“2150 Gas Saw Type #” (the dash number from your serial number). May also be Predator or Woodsman.
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
Take good notes and a some digital photos with as much undisturbed detail of hoses and routing as possible.
Try your local chainsaw seller/mechanic for fuel hose. Take a short length sample, there may be different size hoses. All need be fuel resistant.
Lou
Oct 30, 2009 | Poulan Garden
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2550 Woodmaster Chainsaws Logo
119 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
