Question about Radio Shack Pro-2096 Base Scanner
I have a pro-2096 scanner and now it will not scan up and down the channels it stays on only one channel
sir fixalot
  • 146 Answers
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Posted on Jan 04, 2008
Mechanic688
  • 204 Answers
SOURCE: All channels locked out!!!
You might have to reset the scanner, refer to page 70-71 of your manual. If you need a manual go here,,,
http://support.radioshack.com/manuals/ome20-496.pdf
Hope this helps,,, Mechanic
Posted on Jan 25, 2008
TOLhamRadio
  • 509 Answers
SOURCE: I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER.
need to do a RESET. Then try your local WX frequency to verify it works. The RESET will wipe out all existing programming, just to warn you. Check your manual, or RadioShack.com for details.
Posted on Jan 16, 2010
  • 8 Answers
SOURCE: Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
Posted on Aug 05, 2010
TOLhamRadio
  • 509 Answers
SOURCE: 800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Posted on Aug 10, 2010
I have a radio shack pro 2096 that worked for years came home one day and no digital channels come thru anymore haven't touched a thing?!!
They have probably 'rebanded'- meaning that they moved the control channels. Go to radio reference dot com and see what the control channels are. IF they moved the 3 or 4 control channels and alternate control channels to the 700MHz range, then the PRO96 and PRO2096 probably cannot track it anymore and you will need a newer scanner from Uniden Bearcat or from Whistler. Let me know if there's anything else I can do to help.
Aug 21, 2013 | Radio Shack Pro-2096 Base Scanner
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
I have a radio Shack Pro-2096 scanner. When I scan it says all channels locked out. Do you know how to fix this?
Hello waltz,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
1. Press the SRCH button.
2. Select the bank you want to clear all locked-out frequencies.
3. Press the FUNC, L/OUT. Lockout list will appear.
4. Press 6. Confirm list clear? 1=yes, press another key for no.
5. Press 1 to clear all.
I hope this solution was very helpful to your problem.
Thank you for choosing FixYa.
John
Feb 02, 2011 | Radio Shack Pro-2096 Base Scanner
How do I cleear locked out channels when I cant find them
To review locked out channels and clear them if desired:
- Press MAN
- Repeatedly press FUNC and L/OUT
- Each time you press FUNC and L/OUT the scanner will advance to the next locked out channel.
To review locked out channels in SEARCH banks:
- Press SRCH
- Select the bank to review
- Press FUNC then L/OUT
- Use the up and down arrows to review the locked out frequencies
To clear the locked out frequencies in a bank:
- Press SRCH
- Select the bank that you wish to clear
- Press FUNC then 6
- Select from the options presented
Unfortunately the PRO-2096 does not have a global clear function like many scanners have.
Bill B.
Listening in since the 60's
Dec 12, 2010 | Radio Shack Pro-2096 Base Scanner
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER. IT HAS WORKED FINE BUT NOW IT READS " ALL CHANNELS LOCKED OUT " NEED HELP
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Dec 09, 2007 | Radio Shack Pro-2096 Base Scanner
Display screen looks like something you would bar scan.cannot change to a memory channel
common problem. take it back, or...
open it up, access the small ribbon going to the display, remove from connector, trim 2mm STRAIGHT across with SHARP scissors, clean contacts, insert ribbon back into connector and secure, reassemble.
Nov 25, 2007 | Radio Shack Pro-2096 Base Scanner
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-2096 Base Scanner Logo
37 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
