Question about Refrigerators
Will not cool. compressor is runnung
3.1 refrigerator
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
Fridge troubleshooting
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Nov 27, 2013 | Refrigerators
My refrigerator is not cooling and the freezer is not working. The fan is blowing warm air. What can I do?
I have couple videos of how change compressor on refrigerators. Here is one I did for pizza table, 3 door refrigerator. All compressors change outs will look similar, in some cases takes longer or less time. Hope that will help.
Jul 12, 2011 | Refrigerators
My frigidaire side by side wont get cold. the freezer or the fridge part u can hear it runnung but its hot on the inside
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Refrigerators
Freezer in thawing and fridge is not cooling. hear a clicking noise and seems to be runnung constantly.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 23, 2011 | Microwave Ovens
Refrigerator motor is runnung but both thr frezzer and refrigerator is not cold
heatman101
Dec 11, 2010 | Maytag PTB1953G Top Freezer Refrigerator
How do i remove the ac condenser on a mazda 3
B3E071161450W02
1. Disconnect the negative battery cable.
2. Discharge the refrigerant. (See REFRIGERANT CHARGING.)
3. Remove the splash shield.
4. Remove the A/C drive belt. (See DRIVE BELT REPLACEMENT [LF].)
5. Detach the two wiring harness clamps.
6. Disconnect the magnetic clutch connector.
7. Remove the A/C compressor protector.
8. Disconnect the cooler hose (LO) and cooler hose (HI). Do not allow remaining compressor oil in the refrigerant line to spill. (See Refrigerant Line Removal Note.) (See Refrigerant Line Installation Note.)
Caution • If moisture or foreign material enters the refrigeration cycle, cooling ability will be lowered and abnormal noise or other malfunction could occur. Always plug open fittings immediately after removing any refrigeration cycle parts. 9. Remove the compressor protector.
10. Remove in the order indicated in the table. Do not allow remaining compressor oil in the A/C compressor to spill.
11. Install in the reverse order of removal.
12. Perform the refrigerant system performance test. (See REFRIGERANT SYSTEM PERFORMANCE TEST.)
A/C Compressor Installation Note 1. When replacing the A/C compressor, remove the following amount of compressor oil from the new A/C compressor.
Amount drained (approx. quantity) • 155 ml {155 cc, 5.24 fl oz} - [compressor oil from old A/C compressor + 15 ml {15 cc, 0.5 fl oz}]
Aug 10, 2010 | 2007 Mazda 3
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
Clicking sound,compressor will not start. Fan works but no cooling
try replaceing start kit on compressor. can get a universal start kit 3 in 1 at a refrigeration shop. smaller kit hp . instructions on kit and bag it is in. If does not work... compressor bad. make sure condensor fan motor working also. it keeps compressor cool and helps cooling.
Mar 04, 2010 | Refrigerators
Whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Nov 12, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Fridge runs good for 3 to 4 hours.then turns on but does not cool. i unpug for about an hour and then cools good for another 3 to 4 hours
Are you sure the compressor is turning back on. I would bet that you have a tecumseh compressor in your fridge and when they get hot they don't restart till they cool. The bearings in them go bad. We replace those with Embraco compressors. You unplug it and let it cool down and that is why it restarts.
Sep 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
