Question about ION Audio TTUSB10 Turntable
Needle keeps skipping
Just bought this product, anxious to use it, followed set up instructions faithfully, I think. Although unsure about the counterweight situation. Cannot get even one full track recorded without needle sticking and or skipping. This happens even on an LP that had only been played once and was cleaned. any suggestions, thanks for any help. Sandy
It was the counterweight. I found the instructions a bit confusing for my feeble brain! :) I went back and tried again and must have gotten it right as no skipping now. It works great! I love it.
Posted on Jan 12, 2009
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Skipping straight stitches with proper bobbin size, needle in place same thread for both needle and thread, tried different threads and bobbins that worked before. What can I do please?
Have you checked the tension? That could be one reason for skipping threads. Another cause would be cheap thread. If you don't use good quality thread it can gum up the feed dogs and cause skipped stitches. The third reason I can think of off the top of my head is if you're sewing a fabric with more or less bulk than your previous projects.
Aug 15, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
My cp206r keeps skipping stitches. It will go about 3 inches and then starts skipping them. I have tried to set the timing but it won't hold. Any suggestions out there.
here are some suggestion if they don't help then it would be a good idea to have the machine checked
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 02, 2013 | Consew CP206R Sewing Machine
I have a Hyundai 8 stitch sewing machine and have great difficulty sewing with it. The thread keeps bunching up underneath and misses a lot of stitches. I have followed instructions, both threading up
here is a suggestion for the skipped stitches
Skipped stitches
and since it stops with a crunch,, I suggest having the machine
checked to see why that happening
Feb 18, 2013 | Sewing Machines
Singer 1120 overcast hem foot. Can anyone tell me why my needle keeps breaking? Help! I'm following the manual instruction on how to set the tension and length. So I think it could be the needle size.
I see your question is about a sewing needle but you categorized it as a shoe problem. To properly get this question answered I would try changing the category to a more suitable one. Then the right expert could give you a solution to the problem. Have a nice day.
Feb 09, 2011 | Clothing Accessories
Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
May 03, 2010 | Technics SL-1200MK2 Turntable
How do I get my new needle to stop skipping
Unless you are sewing on a stretch or silky fabric you may need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Apr 01, 2010 | Euro-Pro Shark 60 - 384
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
I have the DT620CL and want to disable the Dawn and Dusk settings.
See "Changing Program Times--Skipping and ON or OFF Event" in the attached manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt620cl.ashx
Find the Dawn or Dusk program time and follow the instructions in step 5 (Turn the selector knob until SKIP shows
in the display and “-- --” replaces the
time (Fig. 17), then press PROG to accept
the new setting.)
Nov 19, 2009 | Intermatic Hardware & Accessories
ION Audio TTUSB10 Turntable Logo
555 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
