Question about Epson Epl 6200l Mono Laser Printer
EPSON EPL-6200 BLACK LINES
We have the above printer, we have changed cartridge, but still has black lines when printing, on at left hand edge, and other in middle of paper. Very annoying! How do you get rid of them?!
ohms
  • 1879 Answers
SOURCE: epson c1100 print problem
you can try this:
remove the toner and photoconductor then tip it GENTLY from side-to-side
reseat them and print
Posted on Jan 04, 2008
  • 4 Answers
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Posted on Jan 08, 2008
Rain041304
  • 63 Answers
SOURCE: epson c66 will not print black
Do print head cleaning. Contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Posted on Feb 14, 2008
  • 2692 Answers
SOURCE: Epson DX8400: how can i get it to print black only
Sorry Desperate. All inkjet printers, from all companies,  are programed to only operate with ink in all containers to avoid other problems. Their is no workaround. Please rate me not harshly just  because you don't like the answer. Rate based upon the truth of an answer.
Posted on Mar 11, 2009
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Colors don't print clearly and black lines run across the page
With Epson, You must use Genuine Epson Cartridges. This is what happens, when they are not.
Epson has it rigged, that way. Believe me, I have learned from experience.
If they are Genuine, then I suggest, use a new cartridge. See what happens.
Most of the Epson, are always on Sale, for a good price. It would cost most to take it to a repair shop.
Good Luck.....
Dec 29, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson rx700, the black prints grey
replace another black cartridge the cartridge is factory defect
Nov 03, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Epl 6200l Mono Laser Printer Logo
170 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
