Question about Whirlpool MH2175XS Microwave Oven
Whirlpool microwave mh2175xs light stoped working i replaced the bulb and it still does not work, I tested the bulb and it is good. Shortly aftre that the turn table stoped working I have it apart and tested the motor and it operates fine when directly pluged in. What should i troubleshoot next
4 Suggested Answers
SOURCE: Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Posted on Nov 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2009
bestdarngood
  • 3037 Answers
SOURCE: My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
Microwave vent won't work
may be short circuit at high voltage section replace diode or magnetron
Jan 26, 2014 | Whirlpool MH2175XS Microwave Oven
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
Lights and turntable work but food does not get hot
may be magnetron or high voltage circuit problem
Nov 17, 2013 | Whirlpool MH2175XS Microwave Oven
My microwavedoesn't heat is there a fuse that may be blown
No! the fuse is fine, there are three likely causes, magnetron, "heats food" cracked high voltave diode, or a shorted high voltage capacitor.
Mar 24, 2012 | Whirlpool MH2175XS Microwave Oven
Microwave stops heating . Its only about 9 months old
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS..thank yuo for choosing fixya..
Jul 10, 2011 | Whirlpool MH2175XS Microwave Oven
Fan stopped working. I am looking for the fuse.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 10, 2010 | Whirlpool MH2175XS Microwave Oven
While changing light bulb, the bulb broke and sparked . This caused the breaker to trip. Since this acurred the Microwave has not worked. no power. I resset the breaker and tested the outlet it has power....
There is a fuse located inside the unit, that has probably blown. This is usually replaced by an appliance repairman - but if you are handy and can remember to kill the power BEFORE attempting replacement, you can save a few bucks.
Whirlpool has made a repair guide or "job aid" for their field service personnel, and it is quite detailed, and includes helpful pictures. Rather than paraphrase it - you can follow the link below and download it yourself. Page 4-6 details fuse access. The link:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eb51f29dbe5773c18525726e00793aa7/$FILE/Whpl%20BaseLineMHC.pdf
Copy and paste the text above in your browser's address box to download the job aid. it is _very_ important that you replace the fuse with the exact replacement. Deviating from the type, style, etc. can lead to fire or nuisance fuse failure.
Please rate this reply if it was helpful to you. Good luck!
Jul 09, 2010 | Whirlpool MH2175XS Microwave Oven
The underside light bulb blew now carousel doesn't turn and interior light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 with a one year guarantee.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation, inside light, or turntable too.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Apr 26, 2010 | Whirlpool MH2175XS Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Need vent grille for Whirlpool MH2175XS
Go to www.partselect.com and type in the model # you will find it there.
Mar 10, 2010 | Microwave Ovens
Whirlpool MH2175XS Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
