Question about Reliance Water Heaters
How to replace anode in Reliance 6402ORS
Where is the anode rod located on a Reliance hot water heater 6402ORS
3 Suggested Answers
  • 252 Answers
SOURCE: cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Posted on Oct 01, 2009
packrat1948
  • 528 Answers
SOURCE: where is the anode rod in a 606 electric reliance
It is the 1" or 11/8" hex nut on the top of the water heater some where buy the supply line. As for the anode rod it could be either depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and water.
Posted on Feb 05, 2011
Change anonde rod in a model 602 40 gal.electric
Maybe in a separate anode port on top of heater... or connected to hot water nipple as a combo
http://waterheatertimer.org/Replace-anode-rod.html
Gene
Sep 13, 2014 | RELIANCE ELECTRIC WATER HEATER
Why is there a bad odor from my 19.9 gallon reliance electric hot water heater
Anode rod?
Replace anode rod, or remove anode rod, and clean tank with hydrogen peroxide (not bleach)
Anode will keep tank from rusting.
Cut new anode rod to correct length using hack saw.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
Aug 25, 2014 | Water Heaters
HOW DO YOU GET RID OFF THE BAD SMELL OF THE WATER HEATERE
1) Replace anode rod: Or remove anode rod. Or install power anode rod. Then flush tank with 2 pints hydrogen peroxide. Do not use bleach.
2) add comment and include brand, type of water heater for possible additional information.
Feb 18, 2013 | Reliance /State Ind. 9002450 Element For...
Anode can be connected to, and part of hot water nipple.
This is called combo anode rod.
http://waterheatertimer.org/images/Anode-top-of-heater-600.jpg
There are also instances where the anode is on top, but does not line up with access holes.
This is more typical with older water heaters.
Don't forget to clean air intake located on bottom of unit, using feather duster or compressed air.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Year of manufacture for Reliance is 2nd and 3rd digit of serial number located on label on side of tank.
Reliance is owned by AO Smith.
Nov 29, 2012 | Reliance Water Heaters
Water is leaking from the pipe on the top of the tank (Reliance 606 electric) where the hot water comes out and goes into the house. Likely causes?
If tank is rusted out, then that is caused by depleted anode rod, or tank that is not electrically grounded on hot side pipe.
If pipe nipple is rusted out, then that can be caused by improper connection between copper and galvanized pipes, and caused by non-grounded hot water pipes.
If tank is leaking, replace it.
If nipple is leaking, remove with pipe wrench, apply teflon tape or joint compound on threads, and install new nipple. Replace anode rod if possible. Correct copper-galvanized connections. Add ground wire between hot and cold pipes.
http://waterheatertimer.org/Leaking-water-heater.html
Aug 25, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance 501 electric water heater ... Everything works great but below the water out. Be rusty? How can I fix it?
The tank is rusting. Replace anode rod or replace water heater.
Once the anode rod depletes, then the tank starts to rust.
IF you can replace the anode rod, it will stop rusting, and then flush the rust out of water heater.
This might buy more life with same tank, but old anode rods are pretty solid and even impact wrench might not loosen it up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Loosen anode rod on new tank before installing, and then inspect every 1-3 years, and 1-2 years if water is softened.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a 30 gal electric reliance 501 240 volt 4500w . getting sulfur smell. I can not find rod to replace.
Anode rods are located on top of tank:
Open links below and watch video.
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
Top of tank has access to anode, but you might have to take metal top off of tank.
Sometimes product manual has details about location, but drawings in manuals are usually generic and not fully informative.
I suggest loosening anode rod before installing tank so the rod can be easily inspected each 1-3 years.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 14, 2011 | RELIANCE ELECTRIC WATER HEATER
Where is the anode rod in a 606 electric reliance hot water heater--is it magneesium or aluminum
Feb 05, 2011 | Reliance & 50gal Electric Water Heater
Does the 501 ahve an anode rod. If so, how do I replace it
Every water heater has an anode rod.
Reliant manuals
http://www.reliancewaterheaters.com/lit/om.html
Reliant is made by American
I don't find a 501 manual under gas water heaters at reliant.
The Reliant manuals that are available do not show the anode rod in the drawing.
But they do show an access port on top of tank.
The anode rod is usually under the access port which is a round plastic disc.
On some water heaters, the anode rod is under the steel top and you have to remove the screws holding the top on.
Some water heaters, the anode is connected to hot water outlet.
Below are two links for the do-it-yourself-er
Oct 23, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
