Question about Mitsubishi WT-42315 42" TV
Mitsubishi WT-42315 42" TV has a red/Green color seperation
Just started happening, thought it was the cables but is happening on all inputs with or without cables
  • 3 Answers
You need to replace the convergence chips, i had this done about a year ago and costs 450.00 usd
good luck
Posted on Jan 18, 2009
I am attempting to connect a Verizon Fios QIP6200-2 HD set top box to my Mitsubishi WT-46805 HD TV using the Y, Pr and Pb RCA connections (no HDMI port on TV) I cannot get any HD channels to work.
The set will have two component inputs, one is NOT HD.
You want to connect to the DTV input which if you look from the back will be marked 480/1080 I .
Also double check the connections to be sure blue-red-red and green to green.
SD TECH
Aug 18, 2010 | Mitsubishi WT-46805 46" Rear Projection...
How can I attach an HDMI BluRay player to my TV
Blu-ray attaches to component inputs. Component cables are the red-green-blue cable and the red and white for sound.
Out on the blu-ray to 'In' on the TV.
Here is your owner's manual. see page 19
Feb 20, 2010 | Mitsubishi WS-55819 55" Rear Projection...
OUR HITACHI 50V500A HAS COLOR PROBLEMS WE MOVED IT
This is an LCD rear screen projection TV. There is a Red, Green and Blue LCD pallet that is mounted on what they call an X-cube. If all you are getting is Red and green then something happened to the blue pallet. Either the Ribbon connector came off or is loose or something worse. How hard did you mover it?
Another thought. How is it hooked up. If component then this may be the issue as component video connections are Red, Green and Blue. Just a thought.
Let me know.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
How do i use my hdtv connection? how do i use it? i want to connect my laptop to my mitsubishi wt-46805 to use as a monitor, can i do that? if so how?
You may also find that you have to change your resolution settings a few times to get the right one for your tv. If both TV and laptop have S-video connections that is a pretty safe bet for connecting both together( small round with four connections)
just a thought, hhope you get sorted :)
Oct 24, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-42315 42" TV Logo
218 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
